Justa6 Member 214 Member For: 16y 30d Posted 20/02/14 10:25 AM Share Posted 20/02/14 10:25 AM On 20/02/2014 at 10:15 AM, BiZkets said: but for how long, how many runs, how long do they last. so what would you think the car would run in 4th. I noticed the car was a au turbo?It's a c4. Yep single cammer au. Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1456780 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 10m 13d Gender: Male Location: Adelaide Posted 20/02/14 10:32 AM Share Posted 20/02/14 10:32 AM (edited) what size turbo it kicks in late but very nice power. there is a guy in sa with a ba/bf motor in a au it go's hard. is yours a turbo au motor then. Edited 20/02/14 10:33 AM by BiZkets Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1456781 Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 9m 6d Gender: Male Location: sydney Posted 20/02/14 11:24 AM Share Posted 20/02/14 11:24 AM so are we talking dyno temps or "REAL" time driving where it counts. I use rapids largest core for my BA and for under $1000 its great.maybe im just getting old but why do numbers count so bad when the car lays rubber in 3rd gear ? 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1456800 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 10m 9d Gender: Male Posted 20/02/14 11:55 AM Share Posted 20/02/14 11:55 AM (edited) On 20/02/2014 at 9:57 AM, ratter said: yes you, you offered I will extract the log and chuck it up toomorrow. Edited 20/02/14 11:57 AM by Kosij Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1456821 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 1d Gender: Male Location: Christchurch, New Zealand Posted 21/02/14 02:59 AM Share Posted 21/02/14 02:59 AM Just to add other info, I was mucking around with the torque app and watch the temps etc. So car is BF2 running 10psi for 285rwkw, ambient temp was 21 deg C and the intercooler is the small factory cooler.I went through 4 90 deg corners that cover under 1km in distance was obviously slowing down and accelerating (little bit of feathering for traction then WOT) to around 100km/h (posted limit). Using 2nd and 3rd gear. IAT started at 30 very quickly went to 49 through that area then took about 10km to get back to 30 with driving on cruise at 100k for 3km then 80k for another 3km then 50km for the last 4km.The factory cooler definitely doesn't do me any favours. Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1456954 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 23d Gender: Male Location: Perth Posted 21/02/14 03:33 AM Share Posted 21/02/14 03:33 AM Factory cooler = poo Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1456977 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 1m 15d Gender: Male Location: Central Coast Posted 21/02/14 03:35 AM Share Posted 21/02/14 03:35 AM Factory anything = pooIsn't that why we modify? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1456978 Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 20y 5m 12d Gender: Male Location: In my house Posted 21/02/14 06:31 AM Share Posted 21/02/14 06:31 AM Yes factory is POO.... Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1457031 Share on other sites More sharing options...
LU82 Bronze Donating Members 569 Member For: 12y 4m 25d Posted 21/02/14 06:57 AM Share Posted 21/02/14 06:57 AM I don't know how accurate any of this info is as im only going off what the car tells me ( outside air temp) and the air intake temp that the torque pro app is showing.My car is still running the standard fg turbo 17psi tapering to 12psi towards the top end on E85 . And a stage one process west stepped cooler.After driving the car for about 40min with a bit of spirited driving in that period I turned on the torque pro app and done 4 back to back runs in 3rd gear wot from 80kmh to 160kmh. ( I could only do it 4 times as the brakes hardly worked after the 3rd run .) The display in the car was showing outside temp was 27c°. Towards the end of the 4 th run while under wot the air intake temp was showing 36c°on the torque pro app. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1457041 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 23d Gender: Male Location: @ my laptop Posted 21/02/14 08:16 AM Share Posted 21/02/14 08:16 AM as I said earlier, that info is most likely not 100% accurate but does give a reasonable indication to what is going on Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/18/#findComment-1457061 Share on other sites More sharing options...
