RAP1D Member Donating Members 3,739 Member For: 18y 11m 8d Gender: Male Location: Sydney NSW Posted 18/02/14 05:10 AM Share Posted 18/02/14 05:10 AM Seriously have to laugh at this thread, lets break it down in to groups.We have serious performance orientated guys , guys that just listen to tuner X and hand over the Visa, guys that are on tight budgets and have to save...And to top it the thread is also comparing 2 seriously different style cores, bar and plate will always cool better than tune and fin,with respect to actual core size tuners experienced in turbo tuning should know this as its fairly common knowledge.Now Im not having a go at any tune shops or independent tuners, there's ALOT of awesome tuners out there, but unfortunately some are not.People need to make educated decisions, forums like this are a great way to obtain information, but are also a place of great bias and confusion.Some good comments from guys that have used X brand cooler with good results, results that at the time of purchase they were extremely happy with, only to see another car later on make 5-10% more dyno read kws, with a different brand intercooler... did they make a poor decision the first time, or have their expectations now changed because they've now seen a higher power result?At the end of the day, for most of us its how the car drives on the road that is the most important, if you like to go out of cruises and run your mates, then on-road performance is what you need to look at, and tube/fin cooler perform totally different to bar and plate cooler.Refresh time... I am yet to see anyone comment on this, tube and fin will always refresh much faster, making your on road inlet temps lower. So what does this mean?Example, your cruising along at 60kays, your mates next to you, tube n fin being a faster temp transfer, will generally mean your motor has lower temps as air is flowing through the core, the bar n plate, generally considered a greater heat sink, thus holding more heat in its heavy dense alloy core.... nail it and you'll probably jump in front, with inlet temps naturally rising on both cores, the tube and fin will heat faster, but then cool its heat soaked temp much faster... so the next run you do your inlet temps have dropped back down fast, where as the bar n plate is still hotter, so now its inlet temps are a bit higher... so you can see how on road performance will greatly vary between the two cores... but if numbers are still your main deciding factor, data log your car, you'll be able to see exactly what temps are coming in and how your tuner has set up temp v IAT correction... Ill talk about this next as E85 and 98 make a huge difference here.We are lucky to have a lot of temp correction tables in the tuning software (SCT, HP , Sniper), the main one that we look at , in regards to intercoolers is Inlet Air temp Vs Spark timing, as mick mentioned early.What is it? basically it is a correction table that is already set up by Ford, to suit the OEM intercooler and 98oct fuel. We have the ability to adjust this, there is no right and wrong for this table, purely governed but the amount of engine knock (ping).Now on a 2010 F6, this table , at 37.8deg C will not add or remove any spark timing.... therefor IF your chosen intercooler hit a max of 37.8deg the computer will not remove and spark from any timing maps, therefor not reduce power from spark.IF the inlet temps go above 37.8 the computer will start to reduce spark, according to how this table is set, thus reducing power. the next temp indicated is 67deg C, with a reduction of around 3deg spark (there is also a multiplying table working at load / rpm that will vary the total spark, but generally 3deg) so IF you were to manually remove 3deg of spark from the motor at WOT, you will loose a fair amount of power... and that is the most common reason power figures vary between core types (of the same size)How do we counter act this? Some don't, they either don't have the confidence to adjust this table, or purely do not know or have not been taught to do so.Its up to the tuner to adjust this table IF they want to, and if they do, they need to carefully monitor knock, and there are a lot more factors that contribute to knock than just inlet temps.Ok so now you have E85 in the tank, inlet temps are now much much less a contributor to knock than 98... Example, My GT runs 11psi at WOT on 78deg C at 7200rpm on E85, with 27deg of spark timing... do not compare this to a XR6T motor as the coyote takes a lot more spark. If this was on 98 it would ping its tits off and break.To back this up I have also run my G6ET at 25psi boost on E85 with NO intercooler at all, none, No pinging , 18deg spark at WOT and inlet temps of 60-70.Funny thing is back in the 90s when I began tuning and working with turbo cars, a lot of us didn't even have intercoolers, so we had to deal with 90+deg inlet temps, to counteract this we ran water/meth mix's to drop combustion chamber temps, this is exactly what E85 does, the inlet air temp may be high, but the resulting combustion temp is greatly lower, thus working against detonation, on 98 you have huge combustion temps, so lower inlet temps will always be ideal over higher temps.End of the day all the coolers on our market perform very well, there all different sized , different prices ect so yes results will always vary, and all tuners tune differently so again results will vary.But one thing I will say is if your running E85, choose your intercooler on airflow, do not worry about variations in inlet temps... so I guess that's pretty much everyone looking at 450kw plus... dropping 5 or 10deg inlet temp on E85 isn't worth even thinking about when tuned with the above compensations taken care of.Im a huge fan of Plazmaman , and ultimately inspired by the work of ProcessWest, and its great to see comparisons like this but people really need to know what goes on in the tuning side of things, and how the final result of a modded XR6 F6 can vary, regardless of who made what and says what. 18 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456142 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 3d Gender: Male Location: Probably above atmospheric pressure Posted 18/02/14 05:28 AM Share Posted 18/02/14 05:28 AM So...PW or Plazmaman? 8 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456149 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 4m 28d Gender: Male Location: WA, Perth Posted 18/02/14 06:14 AM Share Posted 18/02/14 06:14 AM 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456158 Share on other sites More sharing options...
F6Fury Member 135 Member For: 12y 5m 2d Posted 18/02/14 08:39 AM Share Posted 18/02/14 08:39 AM Pw all the way no if buts or maby,s intake temp logging on the Dyno dosnt lie 3 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456201 Share on other sites More sharing options...
10SECN Member 516 Member For: 11y 11m 26d Gender: Male Location: west hoxton Posted 18/02/14 09:25 AM Share Posted 18/02/14 09:25 AM Would be good if u could watch live ait on the sct. Even bodgy microtech a had this 15 years ago. With my rx3 and a tube and fin cooler u could watch the temp rise and fall and u could actually notice cooler air temps idling compared to shutting the car off to cool it off. ( at the track ) 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456213 Share on other sites More sharing options...
Stigmata Donating Members 235 Member For: 12y 3m 14d Gender: Male Posted 18/02/14 09:26 AM Share Posted 18/02/14 09:26 AM Tube n Fin all the way!!!!!! ROFLMAO!!! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456214 Share on other sites More sharing options...
TomT Spooling Member Donating Members 961 Member For: 13y 4m 21d Gender: Male Location: Blue Mountains, NSW Posted 18/02/14 09:50 AM Share Posted 18/02/14 09:50 AM On 18/02/2014 at 9:25 AM, 10SECN said: Would be good if u could watch live ait on the sct. Even bodgy microtech a had this 15 years ago. With my rx3 and a tube and fin cooler u could watch the temp rise and fall and u could actually notice cooler air temps idling compared to shutting the car off to cool it off. ( at the track )$14 bluetooth obdii from ebay and dashcommand app.Eat your heart out. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456216 Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 23d Gender: Male Location: Central Coast Posted 18/02/14 09:52 AM Share Posted 18/02/14 09:52 AM Or torque pro lol 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456218 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m Gender: Male Location: Perth Posted 18/02/14 10:00 AM Share Posted 18/02/14 10:00 AM (edited) Just cram in the widest and highest cooler you can. Its flow and surface area that transfers the heat. I can only say when I went from PW 2 to Nizpro Big Big I noticed a huge difference. Although my PW2 was early one 2007.The lesser the difference in power you notice between summer and winter temps the more efficient your cooler is. Edited 18/02/14 10:05 AM by arronm 4 Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456220 Share on other sites More sharing options...
fehlbie Donating Members 142 Member For: 16y 26d Posted 18/02/14 11:43 AM Share Posted 18/02/14 11:43 AM So what is the pressure drop across the two cores? Link to comment https://www.fordxr6turbo.com/forum/topic/87411-plaz-vs-process-west/page/13/#findComment-1456249 Share on other sites More sharing options...
