  • Member For: 11y 3m 22d
gday guys, new to the forum so not sure if im posting in the right spot but..
just purchased an 08 bfII xr6 turbs 2 weeks ago,
list of mods include;
-bigger fuel pump
-injectors
-4in dump
-hi-flow cat
-HDI intercooler & piping kit
-12psi actuator
-ported wastegate
-SCT flash2
-k&n pod ,opened up box
probably a few more things but you get the basics..
car has had a number of dynos after each mod and last was 369.8rwkw
tuned by bruce heinrick in adelaide
my problem is it just doesnt seem to have the kick in the pants it had when I 1st got it..
its seems the mid throttle response is somewhat laggy and restricted, accelerating at half throttle it surges like its half spooling up and the gear changes are a bit funny sometimes.. unless I give it a boot full it does break traction (even with traction on) but doesnt seem as spirited.. I have lubed the boost solenoid and checked all piping for leaks but am new to turbo cars.. have always been a ford man and a petrol head.. I own a 69 xt falcon with an off tap 347 stroker in it..
any advice would be appreciated..
cheers,
and look forward to chatting more
adam
  • Member For: 15y 6m 26d
call bruce and tell him needs moar 23 in the mid, he will understand.
sorry, what is "moar 23"..?
  • Member For: 17y 5m 27d
Moar = more
23 = PSI
But probably along those lines, get it back to him and have him drive it maybe, see what he reckons?
You've already mentioned the things I'd check. Sometimes I feel mine is the same but it could be I'm finally well used to the extra power after 3.5 years...
  On 30/01/2014 at 10:54 AM, -SteveR- said:
Moar = more
23 = PSI
LOL.. its running a safe tune = 12PSI.. and yes, im probably used to it as my other car is a 347 stroker on NOS
  • 2 weeks later...
  On 30/01/2014 at 7:33 PM, JVK said:
Lots of cars are a bit laggy atm in this heat.
you're probably right, seems better at night...
  • Im the one and only
  • Member For: 20y 4m 14d
Yeah heat kills power.We had 40 degress at christmas and the GT felt so slow...
