blacktur8oute Member 139 Member For: 11y 3m 9d Gender: Male Posted 27/01/14 08:51 AM Share Posted 27/01/14 08:51 AM I have just dummy fitted the PW fuel rail and as it states in the instructions to change orginal bolt with hex bolt provided when I unbolted the orginal bolt I had a bit of coolant enter one of the injector ports will this be ok or should I undo the runner and inspect propely can any damage be caused when car is started at tuner cheers Link to comment Share on other sites More sharing options...
willo88 Member 700 Member For: 13y 1m 13d Gender: Male Location: Newcastle Posted 27/01/14 08:56 AM Share Posted 27/01/14 08:56 AM How much is a bit? And where did the coolant come from? Link to comment Share on other sites More sharing options...
blacktur8oute Member 139 Member For: 11y 3m 9d Gender: Male Posted 27/01/14 09:27 AM Author Share Posted 27/01/14 09:27 AM It come from the top water housing when I removed the orginal bolt to replace with the hex one as pictured I shined a touch can't see any water and also used a vac to suck up to make sure not much went if just a spray for a second or so Link to comment Share on other sites More sharing options...
