Mattzams New Member 5 Member For: 11y 1m 8d Gender: Male Posted 26/01/14 06:46 AM Share Posted 26/01/14 06:46 AM Hi all I've recently had some clutch problems on my GT yesterday the worse by far I couldn't get into 1st off a stand start had to pump the clutch a couple times then it got into first then when I wanted to change into 3rd a few times all it did was grind it wouldn't engage 3rd and when I got in it this morning I noticed that the clutch pedal was still down to the floor it had not released. I was talking to an expert online and he said that it was the clutch master cylinder that was at fault it is not creating enough pressure to push the slave cylinder so clutch disk is not fully released and keep trying to spin the input shaft of the transmission. Is there's anyone that has had the same problem and can help me out thanks. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 7d Gender: Male Location: @ my laptop Posted 26/01/14 06:59 AM Share Posted 26/01/14 06:59 AM he could be correct, it could also be a csc that has failed or something as simple as the clutch fluid needs to be topped up and rebled Link to comment Share on other sites More sharing options...
Mattzams New Member 5 Member For: 11y 1m 8d Gender: Male Posted 26/01/14 07:53 AM Author Share Posted 26/01/14 07:53 AM I hope so I'll know in the next couple of days when I get it looked at Link to comment Share on other sites More sharing options...
Sambo87 Member 26 Member For: 11y 7m 23d Posted 28/01/14 06:39 AM Share Posted 28/01/14 06:39 AM I've got a bf turbo with a t56 and mine had a similar thing.<br /><br />Ever since I bought it (at 100,000k's) it was a little hard to get into gear. Over the next 10000 it gradually got worse and then one day completely f*cked out like you are saying. I'd have to kick the clutch a few times to get enough pressure to get it in gear. That was on the way home from work. <br />The next day I took it to the gearbox shop and the slave cylinder was f*cked.<br />The stock slave cylinder is inside the gearbox and is made of plastic. Common problem.<br />I replaced it with a mal wood opt 3+.<br />I'm still on the run in period so the jury is still out on how good the new clutch is, but I've heard good things from others on here.<br /><br />However I think it may have been slipping this Arvo in 3rd on a full throttle pull because I smelled something suspiciously like clutch when I got to the servo 2 minutes later. I'm running 387rwkw though. The clutch is meant to be good for up to 410rwkw.<br /><br />They come with an alloy slave cyc and billet piston though. <br /><br /><br /><br /> Link to comment Share on other sites More sharing options...
Mattzams New Member 5 Member For: 11y 1m 8d Gender: Male Posted 28/01/14 09:24 AM Author Share Posted 28/01/14 09:24 AM Thanks sambo that's what I think it maybe the slave cylinder has sh*t itself still waiting for the f*cking dealer to get back to me to book it in to get it looked at somewhere in Western Sydney Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 7d Gender: Male Location: @ my laptop Posted 28/01/14 09:59 AM Share Posted 28/01/14 09:59 AM nailing it in 3rd gear is not running it in and will fck it really quickly if it has not bed in Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 7d Gender: Male Location: Perth Posted 28/01/14 10:23 AM Share Posted 28/01/14 10:23 AM Organic plates. Treat with care Link to comment Share on other sites More sharing options...
