MattH12 Member 3 Member For: 11y 2m 28d Posted 25/01/14 08:25 AM Share Posted 25/01/14 08:25 AM Hi,Just wondering if anyone can give me some info on what are the best performance parts to put in/build a fg turbo engine?My car is a 2010 fg a couple of weeks ago it done a oil pump which sucks. Before it done that it had 437kw atw( stage 3 kit put on it ,(exhaust, injectors etc as you guys already know) plus had the turbo upgraded to a GTX35. So now I am thinking of building the engine ( valve springs,conrods,cam,pistons,rods etc) so I am needing some tech help as what to put in it and what needs to be done? I would like to be able to go 550 rwkw to 650 rwkw maybe more if I can afford it.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/ Share on other sites More sharing options...
TomT Spooling Member Donating Members 961 Member For: 13y 4m 16d Gender: Male Location: Blue Mountains, NSW Posted 25/01/14 10:21 AM Share Posted 25/01/14 10:21 AM (edited) +1 for what needs to be done for reliable 550atwSpool rebuild kit, arp head studs and atomic oil pump gears?Need an atomic oil pump or just the gears that are a problem?Bad luck btw mate, mine has 457atw at the moment and you've really got me concerned now haha. Edited 25/01/14 10:22 AM by TomT Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1451936 Share on other sites More sharing options...
jacobmitchell92 Donating Members 370 Member For: 14y 12d Gender: Male Location: Perth Posted 25/01/14 10:29 AM Share Posted 25/01/14 10:29 AM Best bet is too make a build plan with your tuner as they will know what's best and what they like to work with 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1451940 Share on other sites More sharing options...
MattH12 Member 3 Member For: 11y 2m 28d Posted 25/01/14 11:11 AM Author Share Posted 25/01/14 11:11 AM Thanks for the info Tom. Yeah it was a bit of a freak engine. I have got prices from the tuner and they want to just build a complete engine. My mate is a mechanic so he is going to put it all together for me so I am trying to gather everybodys opinions from around Australia what people have had success with and what parts they have not. Instead of getting someone to build it and they say my engines are the best as they all do.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1451944 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 26d Gender: Male Location: @ my laptop Posted 25/01/14 12:27 PM Share Posted 25/01/14 12:27 PM just a friendly warning, there's more to building an engine correctly than just bolting a bunch of parts together 2 Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1451955 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 25d Gender: Male Location: Canning Vale, W.A Posted 25/01/14 02:09 PM Share Posted 25/01/14 02:09 PM Isn't it just like lego? I'm boned then 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1451959 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 23d Gender: Male Posted 25/01/14 02:48 PM Share Posted 25/01/14 02:48 PM My mate had a mechanic friend (just out of apprenticeship) who offered to build his performance engine. My help was asked for when this "mechanic" couldn't work out why the engine would not turn when he bolted it all up.Now lets start.Crank wouldn't turn cause the big end caps were put the wrong way aroundUpon disassembly the pistons were on the wrong way around on the rodsThe top and bottom ring clearances were the wrong way around .Just food for thought. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1451960 Share on other sites More sharing options...
Handrl Member 36 Member For: 15y 2m 20d Gender: Male Location: Perth Wa Posted 25/01/14 03:11 PM Share Posted 25/01/14 03:11 PM I just built my engine for fg xr6t b a few months ago but I wanted real reliability and so I went brand new Fg block new crank manley I beams (1500hprated)billet oil pump gears manley forged pistons and upgraded pins, nizpro girdle, arp 2000 head studs full reckon head crow valve springs and retainers arp 2000 head studs new cams standard with machining etc but I wanted pretty good gear in the engine I could of saved a few k going spool gear but didnt want that personal preference you get what you pay for in the end good luck with it Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1451961 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 26d Gender: Male Location: @ my laptop Posted 26/01/14 12:29 AM Share Posted 26/01/14 12:29 AM turbotrana makes some good points but I was thinking more along the lines of what sort of clearances is he going to use and based on what experience, there are a quite a few builders that can these days build a strong a strong engine that is not noisy, which means the knock sensors can still be used for safety. If you go by the common clearances for piston to bore then most the time you have a noisy engine.A good engine builder will assemble an engine several times and get the clearances to where they require, a guy doing this at home is not going to in most cases dummy assemble, then strip and send the parts away again possibly several times until the correct specifications are meet Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1451994 Share on other sites More sharing options...
MattH12 Member 3 Member For: 11y 2m 28d Posted 26/01/14 05:19 AM Author Share Posted 26/01/14 05:19 AM Ha ha good comment turboboink. Thanks for the info handrl. If you don't mind me asking how much did it cost to build the engine?What sort of rwkw did you get out of it? Did you build it or did you get someone in Perth to build it for you? Link to comment https://www.fordxr6turbo.com/forum/topic/87363-building-a-fg-turbo-performance-engine/#findComment-1452009 Share on other sites More sharing options...
