  • Member For: 11y 8m 27d
hey guys I just bought a a brand new bf typhoon motor from ford just wondering what power can I push with pump fuel and what can I push with e85 standard turbo?
what goodies have they got in them (specs)
and believe it or not it was cheaper than a normal xr6 turbo motor go figure
https://www.fordxr6turbo.com/forum/topic/87361-bf-typhoon-short-motor/
  • Im the one and only
  • Member For: 20y 3m 14d
I believe that the BF F6 motor has LPG conrods out of the LPG motor.I think everything else is the same.As for power, Most people in the day used to hang around the high 300,s for safe margin. I aslo think the stock turbo is good for around the high 300,s as well.
Some one will probably clarify..
  • Member For: 14y 6m 10d
Have a good look at the RH engine mount boss on the block. I bought a Typhoon long from Ford for my BA, and I believe it has an FG bottom end. RH engine mount bracket had to be modified to fit, which has to be done if fitting FG short to BA/BF.
  • Member For: 12y 7m 8d
id be interested to find out the difference between in strength for all the models as well
BA T -
BA F6 -
BA/BF LPG -
BFT -
BF F6 -
FGT-
FG LPG -
FG F6 -
  • Bronze Donating Members
  • Member For: 11y 9m 20d
iirc, the;
BA is one make
BA f6 is different bottom end
BF (could be identical to BA)
BF F6 is the same as BA
BF2 xr6t has the same internals as F6
As far as I know;
All F series motors are the same. The differences come in the programing, turbo parts, bolt-ons, aux etc.
In all, having a BF F6 is the way to go as the turbo is so oversized for the job, the limit starts to be the fuel sys early on. The FG's went to smaller turbos & thus more money needs to be spent when you start looking around 350's with the xr6's. Not sure if the FG F6 has a ceramic turbo as well.
  • Member For: 15y 5m 26d
not entirely true
fg f6 has different pistons
all bf turbos are the fg f6 turbo
so which is stronger out of the bf f6 or the fg n/a in rod size and do they all have cast pistons , just thinking of buying an n/a fg bottom end .
  • Member For: 19y 4m 3d
N/a is more than likely to have the small rods even in fg ,may aswell buy the gas engine with big rods and higher compression if using e85. Pretty sure your tuner Rapid had previously done this on a G6et quite a while ago with good results.
