  • REST IN PEACE V8
  • Member For: 17y 10d
Just out of curiosity who has run a external gate off there exhaust housing on a gtx35/82 and lost power compared to the internal gate been told this is a common issue
  • Member For: 15y 10m 29d
It depends where the gate is plumbed into the housing, The further around the housing the worse it gets. I've seen a loss of 30kw on a car just from the gate position.
  • REST IN PEACE V8
post-15304-139042927142_thumb.jpg<br />Yeah exactly my car is down 30 rwkw <br />
  • Forged Member
  • Member For: 18y 2m 24d
Yeah, that's why... Where the flange has been placed is no good for exhaust flow, that is asking the exhaust to build up in the rear housing and then do a 90 degree turn back against itself to get out to the gate.
It really needs to be flowing in the same direction as the exhaust gases so when the gate opens there is a smooth gas flow back in to the exhaust
  • REST IN PEACE V8
30rwkw down on 6 psi more boost I'll just get tuner to smash more boost very expensive exercise to make less power
  • Like 3
  • REST IN PEACE V8
  On 22/01/2014 at 10:42 PM, senna_T said:
Yeah, that's why... Where the flange has been placed is no good for exhaust flow, that is asking the exhaust to build up in the rear housing and then do a 90 degree turn back against itself to get out to the gate. <br /> <br />It really needs to be flowing in the same direction as the exhaust gases so when the gate opens there is a smooth gas flow back in to the exhaust
<br />It is on a low mount 6 boost manifold so turbo is mounted upside down
  • Forged Member
Yeah but imagine the way the exhaust gas flows, to have the flange at a right angle like that means that it's going to come from the manifold and start following the rear housing around to the turbine but before it gets there it is running in to a wall half way around. I'll try to find a photo of what I think it should be.
  • Like 2
  • REST IN PEACE V8
Yeah I understand what your saying in the years of modding cars I just have had them off the manifold and never had a problem thanks for your help just bit pissed I went on some wrong advise
  • Forged Member
This is kind of what I'm talking about, see how the pipe has been cut to flow the gas straight from the flange at the merge collector?
  • Like 3
  • Forged Member
Pain in the ass I know, but if you can get a new rear housing and have this done I think you would see the benefits of holding solid boost curves with the external gate :spoton:
