Sambo87 Member 26 Member For: 11y 9m 20d Posted 28/01/14 06:43 AM Share Posted 28/01/14 06:43 AM Are you taking about a bf Matt? His is a BA. Different kettle of fish. Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452276 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m Gender: Male Posted 28/01/14 12:08 PM Share Posted 28/01/14 12:08 PM On 21/01/2014 at 11:02 AM, Adran said: Hi all... I have read most modification threads but what I want to know is how much power can the BA engine and transmission run daily safely before a rebuild on either components and how much it will cost... I am chasing 300rwkw running abt 15 psi boost max... Anyone got their story to share?Thinking your brave doing that. Don't know much about their turbos but valve springs is the first thing that'll let go, they let the eng rev out more to gain the power. Bottom ends on a BA aren't as good either as a BF2 or a F6. Fuel may be a limitation so a small upgrade to injectors is probably good. Inductions on the B series are average so getting a good cooler & pipework is a plus.I hear a lot of ppl running as standard mods a 12lb actuator ported wastegate, overhauled induction, big fuel system & a dump/cat combo getting mid 300's without too much issue. In short though, if your going to put something like 5 times the boost in without upping the rest of the components, running 98, just keep a bucket in the back of the car to pick up engine parts you drop on the road. Not saying putting that much boost in is bad, but its bad 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452350 Share on other sites More sharing options...
Adran Member 38 Member For: 11y 7m 4d Posted 28/01/14 01:35 PM Author Share Posted 28/01/14 01:35 PM Thank you for everyone's stories and advice... I think I will start with the valve springs and a capa cooler... Then start thinking of where I want to go from there... As in Stage 2.1 PW cooler... Dump & cat...1000cc Injectors... Surge tank for e85... trans rebuild... And engine rebuild when it goes bang... In those order... Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452362 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m Gender: Male Posted 28/01/14 01:49 PM Share Posted 28/01/14 01:49 PM (1000cc's are dam big. If your aiming for 300's, 60's are enough) Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452363 Share on other sites More sharing options...
Adran Member 38 Member For: 11y 7m 4d Posted 29/01/14 12:15 AM Author Share Posted 29/01/14 12:15 AM I hear you fiftyone... But they are essential for e85 according to my tuner Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452391 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m Gender: Male Posted 29/01/14 10:59 AM Share Posted 29/01/14 10:59 AM Aren't you only talking 300 though? It doesn't matter the fuel, it'll be the internals that will be the issue going for numbers first Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452473 Share on other sites More sharing options...
Adran Member 38 Member For: 11y 7m 4d Posted 29/01/14 02:15 PM Author Share Posted 29/01/14 02:15 PM Yes I am gng for 300rwkw... As the price difference for 600 and 1000 is $295... It will give me the option to chase 400rwkw if I choose to down the track... Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452499 Share on other sites More sharing options...
matt036 Donating Members 280 Member For: 15y 3m 24d Gender: Male Posted 30/01/14 05:00 AM Share Posted 30/01/14 05:00 AM On 28/01/2014 at 6:43 AM, Sambo87 said: Are you taking about a bf Matt? His is a BA. Different kettle of fish.Nah bud, mines a BA Mk2 so still plasticine rods in it. Definatly not bf.Mate if you plannin on goin bigger later then you might as well get the parts that will support it now, saves buying twice and when the time comes one less thing to buy. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452581 Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 10m Gender: Male Posted 01/02/14 06:07 AM Share Posted 01/02/14 06:07 AM On 29/01/2014 at 2:15 PM, Adran said: Yes I am gng for 300rwkw... As the price difference for 600 and 1000 is $295... It will give me the option to chase 400rwkw if I choose to down the track...That's all good, but with the larger injectors you might need different plugs (injector connectors) & the impedance of the unit might not be supported via the ECU. That & idle quality might go to sh*t if the pulse rate is too short for what your trying to do. Big freakn injectors, all I'm sayn'.Better to build the system in stages of performance to your tuners suggestion than to oversize some parts too early. Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452896 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 4d Gender: Male Location: @ my laptop Posted 01/02/14 07:36 AM Share Posted 01/02/14 07:36 AM Bels G6ET currently has 1250 injectors in it and it idles on 550 rpm with no issues at all, no adaptors were required, although on a B series, extensions would be required Link to comment https://www.fordxr6turbo.com/forum/topic/87338-ba-xr6t-engine-mod/page/2/#findComment-1452901 Share on other sites More sharing options...
