winton Member 9 Member For: 11y 29d Gender: Male Location: qld Posted 18/01/14 08:42 AM Share Posted 18/01/14 08:42 AM Some pg questions , just after some info to gather parts.Are the 6 and 8 Boxes interchangeable internally?Bell housings to fit 4l , all the pg's I've seen have the bell cast to the housing. Are you guys running pg's cutting off the bell from the housing ,can they be found with a removable bell or are you using after market cases? fitting the new bell, are you guys fixing the bell through the pump bolts? Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 1m 12d Gender: Male Location: North West Hot Hell,VIC Posted 18/01/14 09:34 PM Share Posted 18/01/14 09:34 PM Powerglide parts are interchangeable between the 6 and 8cyl boxes. Expensive Daewoo 6 and 8 boxes had unboltable bellhousings and the chev box had the all in one cast bellhousing which still could be cut off and a new housing bolted on. There are also aftermarket cases such as Reid ( I think that's the name) but these are expensive. You can get different ratio 1st gear set for these boxes ,I think from memory the 6 had a 1.7x first gear and the 8cyl had a 1.82 first gear ratio. 1 Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 2d Gender: Male Location: @ my laptop Posted 19/01/14 01:52 AM Share Posted 19/01/14 01:52 AM a powerglide can be made using totally aftermarket parts, a stock powerglide is not a very good box 1 Link to comment Share on other sites More sharing options...
winton Member 9 Member For: 11y 29d Gender: Male Location: qld Posted 19/01/14 03:55 AM Author Share Posted 19/01/14 03:55 AM Thanks for the replies. Link to comment Share on other sites More sharing options...
