Project 305
rednose
  • Moar Powar Babeh
  • Member For: 19y 4m 9d
I totally missed this thread, I ran 295/35/19 Federal 595rsr's for a while. They measured 309mm shoulder to shoulder on a 9.5Axis hiro.
I made up spacers similar to yours for the Control Blades (if I seen this thread sooner I would have given them to you! I binned them a couple of weeks ago)
I had to roll the shiiit out of the guards and trim the body work where the bumper meets the bumper inside the guard.
tractions was not and issue!
  • Moar Powar Babeh
Spacers where aprox 13mm to get around 5mm clearance, Can't recall the offset will need to check.
What height are the 305's? I had issues with the tyres touching the inner guard on the inside when the suspension copped a rapid compression, couldn't do much to sort that bar raising the rear to 70's hotrod spec.
  • RNS10S
  • Member For: 18y 5m 16d
My current 9.5 Hiros are +40, the new 10.5's are +42 so will only need 11mm on the outside.
The current 275 35 19 Hankook Ventus RS3's did not touch anywhere and the rear quarters wer not rolled.
I have now rolled the guards and will be going to a 305 30 19 so hoping the lower profile helps a bit too.
When we put the test wheel and the current wheel next to each other there was a decent reduction in height, the 305's are definately shorter.
  • RNS10S
Fit the 12mm spacers today and test fit the wheel
7C47BD7D-DAF6-45ED-8D45-4B6BC7C27FC9_zps
In this pic there are 2 guys siting in the boot and one in the rear seat, probably the lowest the car will get.
Very happy with the result so will be purchasing tyres
  • Like 2
  • 1 month later...
  • All stock bar the k&n panel filter
  • Member For: 12y 10m 19d
Just for anyone who may be interested in doing something similar to this, KPM Motorsport sell a control arm spacer kit that will give you an extra 10mm clearance on the inside. I ordered a set today, cost me $195 for the kit plus $20 for the airbag to Perth.
