The Converted Donating Members 344 Member For: 13y 9m 3d Gender: Male Location: Melbourne Posted 17/01/14 10:57 AM Share Posted 17/01/14 10:57 AM G'day guys and girls.Thought I'd finally share what I've done to my car in the past 12 months.Engine Built by Dion at Dyno-Mite PerformanceJE PistonsArgo rodsBillet oil pump gearsHD Timing chain and tensionerStrengthened and ballanced standard crankHead ported and polishedDyno-Mite custom camsARP 12mm head studs with Dyno-Mite head stud plates.Bolt onsPlazmamanFuel RailPlenumB.O.V.Process West;Battery relocation4" Cold air intakeStage 4 IntercoolerTwin 044 Surge tankGTX3582R Internally gated with Turbosmart actuator on stock manifoldID2000 injectorsFPR1200C.E.S. 4" ExhaustTransTurbo400 built by Andrew at Preston AutomaticsFully manualized with Quicksilver reverse pattern shifter modified to look factory manual 6 speed in the cabinTransbrakedCustom one piece tail shaft with trans tunnel loop at the front uniRear endTrutrac diff centre with 3.73 gearsDrive Shaft Shop 1400hp CV shaftsWholesale Suspension adjustable upper control armsCurrently makes 460kw @ 6900rpm on E85 and ran a P.B. of 10.19 @ 135mph at Calder in NovemberThe plan is to run a 9.999 or better with the current setup and then the GTX4202R goes on. 4 Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/ Share on other sites More sharing options...
xrlook Member 153 Member For: 16y 10m 20d Gender: Male Location: sydney Posted 17/01/14 11:10 AM Share Posted 17/01/14 11:10 AM Good work mate, looks awesome. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450755 Share on other sites More sharing options...
willo88 Member 700 Member For: 13y 4m 16d Gender: Male Location: Newcastle Posted 17/01/14 11:35 AM Share Posted 17/01/14 11:35 AM LBSVAG. Best. Plate. Ever 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450757 Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 9m 3d Gender: Male Location: Melbourne Posted 17/01/14 12:23 PM Author Share Posted 17/01/14 12:23 PM Not everyone understands them willo88, I'm glad you do.Got no decent footage of the 10.19 but here's a video of a 10.43 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450760 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 2m 28d Gender: Male Location: Perth Posted 17/01/14 12:42 PM Share Posted 17/01/14 12:42 PM That gearbox is rad! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450762 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 2m 28d Gender: Male Location: Perth Posted 17/01/14 01:12 PM Share Posted 17/01/14 01:12 PM Seems somewhat like the rally car gearboxes...if I was building a racer that would definitely be the way I'd go. Well played sir, well played! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450764 Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 9m 3d Gender: Male Location: Melbourne Posted 17/01/14 01:26 PM Author Share Posted 17/01/14 01:26 PM (edited) Thanks dowen but it's not the same as a rally car, the style of shifting is similar though.This is an automatic transmision is from the 60's/70's that has been rebuilt to handle 1500hp and adapted to fit behind the barra Edited 17/01/14 01:26 PM by The Converted Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450765 Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 13y 2m 28d Gender: Male Location: Perth Posted 17/01/14 01:41 PM Share Posted 17/01/14 01:41 PM Haha yeah, I just meant in terms of shift pattern. I read above about it being an auto box. Looks like you've put in a whole lot of effort, good to see :-) 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450766 Share on other sites More sharing options...
The Converted Donating Members 344 Member For: 13y 9m 3d Gender: Male Location: Melbourne Posted 17/01/14 01:43 PM Author Share Posted 17/01/14 01:43 PM Cheers brother.. a lot of time and effort spent on this one. Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450767 Share on other sites More sharing options...
speedtrap Member 7 Member For: 12y 6m 16d Posted 17/01/14 03:59 PM Share Posted 17/01/14 03:59 PM Nice!!Had me fooled read the start skipped the trans part because I seen pics then watched vid. had to go back n re read.If you don't mind me asking, any idea what kph you are pulling each shift?? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87309-ba-xr6t-460kw/#findComment-1450772 Share on other sites More sharing options...
