Timing Chain Help Required
eaturbo_39
  • Member For: 11y 11d
Hey guys newby on this site and I need some assistance upon replacing my head gasket on my xr6t I put the engine to TDC and now its all back together but the timing chain does not match the yellow tags I thought were timing marks has any one got a pic of the timing marks or any info on it please. For it to line up now its 180 degrees out is this right?
  • Member For: 12y 5m 21d
Ouch, should have put paint marks on the chain when took the rocker cover off, you will probs have to take front timing cover off to line the chain up with the bottom gear and the get the cam gears ligned up, some one else on hear might have an easier way!
Sent from my iPad using Tapatalk HD
Yeah I have timing cover off already and just found the marks lol blind as a bat I must have been. For any one else chasing the info the yellow chain link lines up with a small line on the crank shaft and then the orange one lines up with a mark on the teeth of the crank shaft gear . The cam gears have small dots on them below the teeth with both point straight up and the yellow chain links line up with those at the top
