rob2489 Member 18 Member For: 14y 11d Gender: Male Posted 16/01/14 10:55 PM Share Posted 16/01/14 10:55 PM Hi Guy'sI noticed a few day's ago my rear muffler split around the weld joining the pipe. So I started hunting for a replacement. Then I managed to score a new complete standard system of a 2012 XR6T for $80 that only had 1500kms on it. Was going to fit it this week end when I came across an X FORCE mild steel twin 2.5inch cat back system for $380. Not sure what to do here. My question is -Is the twin 2.5 x force system much better performance wise than the new standard system I'm about to put on? Not worrying about sound more is it worth the $300 difference in price? being I already have the new standard system ready to goMy G6Et is tuned and is putting out low 300'sI need to act soon any advice would be fantastic Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 5m Gender: Male Location: Adelaide Posted 16/01/14 11:51 PM Share Posted 16/01/14 11:51 PM get it Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 3m 15d Gender: Male Location: Perth, WA Posted 17/01/14 12:34 AM Share Posted 17/01/14 12:34 AM Is the xforce cat-back brand new? The reason I ask is because they are about $550 brand new.Do you want a quiet exhaust or are you not fussed with a bit of a note?The xforce should flow a bit better of the stock single 3" so this would probably yield a bit more top end. Link to comment Share on other sites More sharing options...
rob2489 Member 18 Member For: 14y 11d Gender: Male Posted 17/01/14 01:37 AM Author Share Posted 17/01/14 01:37 AM Is the xforce cat-back brand new? The reason I ask is because they are about $550 brand new.Do you want a quiet exhaust or are you not fussed with a bit of a note?The xforce should flow a bit better of the stock single 3" so this would probably yield a bit more top end.No it's second hand and by looking at the pics had a fair bit of usenot really fussed about noise rather a bit quieter than louderIf they are $550 new it is not worth the $400 usedcheers Link to comment Share on other sites More sharing options...
