First Trip To The Strip
unclewal
  • Member For: 14y 5m 11d
Finally got my Ute to the track yesterday got 5 runs in total with the hottest one starting at 38 degrees and getting cooler as the night ran on, unfortunately I left my tyre pressure up high and it skated in 3rd and 4th at the top of the track. I managed on the 4th run a best of 12.76 @121Mph, just couldn't get the launch right and kept bogging of the start. My main concern was the strength of my driveshaft and trying not to break it. Something odd on the night was it felt like it was hitting the limiter in 4th gear.
I managed to watch the tacho and it appears only in 4th gear at 5300+ the car started to miss/rev limit. Now I know that rev limit is set to 6200 so its not the limiter its hitting. I am suspect its blowing the spark out, but not sure why it would do it in 4th gear and not the other three unless its load based in which case 190km/h worth of wind might do that. I am going to pull the plugs tonight and see if there is anything built up or if they are burnt etc. I dont think its running out of fuel I have a surge and 2 x 044's and PW fuel rail, just odd I thought it was hitting the limiter when it wasnt. Either way a good experience on the track and might come back again in Feb for another go, either that or take my bike and try and run a 10. I have 3 videos of my first, best and last run taken from my go pro I will post up when I get home.
The box was a bit clunky into second, always has been.I am making 455kw at the wheels on E85, I had 55psi in the tyres on the first run, forgot to take road pressure out of them.... I didnt want to rip it too hard to get it to skid in second, will give it a shot next time and hope not to stall it, the drive shaft is still stock.
Shouldn't be starved of fuel I have surge twin pumps and pw rail. Only way to tell would be dyno time I guess. Gonna change the plugs and go from there. The hand brake was so I don't have to screw with brake pedal and not go over the line
