  • Member For: 17y 4m 19d
  03XR6T said:
Good luck with that large turbo! You'll need to have a bulletproof driveline, that launch control/flatshifting program & a higher rev limit than factory to make use of the 45R...
All the driveline is done bar the diff area. dont really care if I blow, it needs to be done anyway. Rev limiter wise the car will go safely to 7000rpm. Pat's installing some atomic cams as well to help it up high.
  senna_T said:
Totally agree mate, but Brian was also only running low profile Toyo R888s when he ran, and if I may say so he was still very green at drag racing!
This will be no easy task, but I beleive we have the set-up to do it.
I will be running some very grippy semi slicks, as Pat say's the car has the set up to do it so its just down to me and im pretty confident I have the driving ability to crack an easy 10 in this car. I guess its just a case of watch this post.
  F6 UTE said:
There's been plenty of manual setups that should go quick, should run 10's - or even 9's. But they never do.....
Bring the thing over to WA and I'll give it a proper thrashing :P
Good luck with it though - but you still haven't learnt that revs wontt get you there, even 7000 of them :) I don't rev my evo to that and it's set at 7800k.
Keep us posted - to date we haven't seen a time posted in this thread, even a ballpark or starting one - plenty of questions though????
Any more info?
Well there's a good answer to that question mate, I need the car in order to run it down the strip. Once Pat is done fitting the new camshafts and he gets back all my manifold/turbo gear from being ceramic coated, the first thing im doing is running down WSID.
P.S Dont compare my car to an EVO please, that's a massive insult :idunno:
  • Member For: 18y 15d
  Worm said:
Would be nice to see a manual in the tens!!!
Is it that quick Senna?
:innocent: Could you see a 10 with a perfect run?
  • Forged Member
  • Member For: 18y 4m 3d
Well it will definately have the power, we'll see how it goes in the next couple months once the motor is run in and fully tuned. I would say the only other manual car to have gone down the strip with this much power would be Brians, so that should give you an idea of the power we are expecting
  • Member For: 17y 11m 16d
All the very best on beating that time....but just a qst. Does the current record holder run that 11.3 or so in a factory turbo or is it an upgraded turbo..
Im all for records and that and I understand that youll be running against that time with a gt45r....if so what is the record for a standard turbo , because I think that there should be 2 groups for records...1 is to have standard turbos and the other aftermarket bolt on turbos class.
I just dont think that its fair to put them together in the same group.
