  • - Track Bound EVO III -
  • Member For: 20y 5m 26d
  YLD-11Z said:
ah maybe, not too sure, I know of one other with one. that black ute running 600rwkw plus has a gt42r. heres an engine bay pic of mine from a few weeks ago
You might want to add some aluminium pullies to that list.
11 seconds sees them as a requirement - on a real drag strip.
  • Member For: 17y 4m 19d
  F6 UTE said:
bring the excuses out now ladies - there won't be any room for them later.
no excuses here, go hard or go home
  • Forged Member
  • Member For: 18y 4m 3d
For those of you wondering what else is done to Andrews car I'll add a couple I can remember now:
The GT45 has 1.05 rear and .66 front (should be responsive)
The head has 14.3mm head studs
Stage 2 valve springs rated to 35+psi
Lightweight Mahle pistons run factory comp ratio (better low end response)
Balanced crank
Atomic Mains Girdle
ACL Bearings
870cc Bosch injectors
The wastegate is a 60mm Turbosmart unit
Andra approved Balancer
I think that's it for now, but as Andrew has said, JEM will be doing the tuning (Adam from JEM basically graduated from Haltech rather than school!)
The original plan for the car was to make 500+rwkw, that's how we went about preparing the set-up. Andrew has decided to go down the dragstrip with it, so we'll support him and adapt the set-up to drag as much as possible
  lukexr6t said:
I run a couple of altereds in modified so I no what that sh*ts all about
good luck with the times mate, its good to see the manuals coming out of the woodwork
Balanced crank
Atomic Mains Girdle
ACL Bearings
Thanks for clearing that Pat, the original plan was to have a dyno car which it still will be but after going to the latest andra drag meet, I just couldnt help myself, I think its in my blood
Edited by YLD-11Z
  • A much better forum
  • Member For: 16y 10m 19d
Which street tyres were you running to do 11.41?
  • Member For: 19y 4m 19d
I tried launching with revs but the thing axle tramped 1st 2nd and if you peddled it in 3rd it would hook up
,the quickest past I launched real soft and started getting into it softly 2nd and then 3rd it makes 30mph from half track so obviustly stand on it in 4th and you will need a 6500rpm limiter if you want to stay in 4th on stock diff ratio.
