  • Member For: 12y 9m 13d
Hi I am in need of new sway bar links for the rear of my ba xr6t as the rubbers where it bolts to the actual sway bar are shot.
I am aware of 2 different desighns, one being a ball joint at top and bottom, similar to the front desighn and the other is just replaement bushs from nolthane, whitline or superpro.
so which would be better? to me I would say the factory one with replacement bushs would be stronger? as teh ball one may move around under load?
opinions?
http://www.ebay.com.au/itm/BA-BF-FG-FALCON-TERRITORY-MONDEO-REAR-SWAY-BAR-LINK-BUSHES-FORD-NOLATHANE-42457-/170995731183?pt=AU_Car_Parts_Accessories&hash=item27d023caef&_uhb=1
or
http://www.ebay.com.au/itm/Ford-Falcon-BA-BF-REAR-Sway-Bar-Link-Pin-Stabilzer-HD-Design-Swivel-Ball-Joint-/380746257582?pt=AU_Car_Parts_Accessories&fits=Plat_Gen%3ABA&hash=item58a63ed4ae&_uhb=1
  • Forged Member
  • Member For: 18y 2m 29d
Our ball joint design is superior to the original style since it removes the vertical play in the bushes which slows response from the swaybar. In other words as the suspension loads up, the bushes squash and move first then the swaybar moves. With our design there is no delay.
cheers, with your desighn is there still bushs where it connects to the control arm? if so what ones do you use? the factory bush or aftermarket?
  • Forged Member
^^^ This, just two washers to locate the stud in the arm, no bushes at all
cheers guys so the washers have locating parts on them? as I know the hole is rather large compared to the stud
  • Forged Member
Can't comment on others, but ours definitely have all the right washers
  • 4 months later...
  • Member For: 13y 2m 15d
Sorry if this is a stupid question,but im trying to install these atm, how do you stop the upper ball joint from spinning when your tightening the top nut on the lower control arm, is the only way to put a spanner through the hole in the LCA?
