Jip86 Donating Members 12 Member For: 11y 10m 25d Posted 12/02/14 12:00 PM Share Posted 12/02/14 12:00 PM Pw 2.1 kit, pw surge, x force 3.5" split dump with dual 2.5" system, wastegate modded/flapper, 12lb actuator, 60lb injectors. Ended up just shy of 400rwkw at 18psi. Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/page/2/#findComment-1454870 Share on other sites More sharing options...
Krazy Kyle Get It To Wheelspin Uncontrolably Then Give It Another 5 Pounds Cruise Control 2,697 Member For: 14y 6m 14d Gender: Male Location: Work Posted 20/02/14 12:41 PM Share Posted 20/02/14 12:41 PM update? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/page/2/#findComment-1456836 Share on other sites More sharing options...
Vrdesign Member 42 Member For: 11y 4m 6d Posted 30/06/14 11:56 PM Author Share Posted 30/06/14 11:56 PM hi, finally backwith an update.So the conclusion is, dont waste your time with a front half upgrade only! the stock cat back is no good over 300kw( yes, I know alot of people do, but they are wasting their time)I gained 10rwkw, and 22nm of torque witht he front half. the change was slightly noticable down low, but nothing special.Yesterday I fitted a twin 2.5, and WOW The car is a bullet, if the dump only gained 10rwkw, then I have easily gained another 20-30 rwkw ontop of that with the cat back upgrade. Totally different car to drive.for an extra $500 its no brainer. please learn from this. They definately go hand in hand, do not persist with the stock cat back.retune in a week or so, will keep you posted.thanks Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/page/2/#findComment-1482035 Share on other sites More sharing options...
