Vrdesign Member 42 Member For: 11y 4m 6d Posted 09/01/14 04:13 AM Share Posted 09/01/14 04:13 AM (edited) im looking at upgrading just the front half of my exhaust (BF Sedan, 4" dump, cat, 2 x 2.5" merge pipe) currently stuck at 300rwkw, looking for around 330-340rwkw. not sure if the stock cat back will be a restrction.I was hoping to hear from someone who has done the front half first, but then later down the track decided to upgrade the cat back to find out that;a) it made no difference in power, and the stock cat back was ok for this power rangeb) the stock exhaust was a restriction and it made a decent power gain on the same boost.currently have stock cat back with 2.5" hotdogs front and rear, so I have noise already!Cheers Edited 09/01/14 04:15 AM by Vrdesign Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/ Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 9d Gender: Male Location: Far north queensland Posted 09/01/14 04:59 AM Share Posted 09/01/14 04:59 AM 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1449057 Share on other sites More sharing options...
Vrdesign Member 42 Member For: 11y 4m 6d Posted 09/01/14 09:39 PM Author Share Posted 09/01/14 09:39 PM already have 100cpi 5" cat on the std dump... Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1449165 Share on other sites More sharing options...
Vrdesign Member 42 Member For: 11y 4m 6d Posted 27/01/14 09:56 AM Author Share Posted 27/01/14 09:56 AM Just a quick update, fitted an xforce front half of the exhaust, 4" dump, cat and merge pipe. Car was tuned at 14psi, boost now hits 18 psi! Massive difference, response is much better, and power comes on a lot earlier. Time for a re tune! Fitting wasn't too hard, the only issue I had was 1 of the 5 bolts where it connects to the turbo (bottom) was a pain to access with any normal tool. And had to modify the heat sheild which covers the steering arm. Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1452129 Share on other sites More sharing options...
xrlook Member 153 Member For: 16y 9m 14d Gender: Male Location: sydney Posted 27/01/14 10:31 AM Share Posted 27/01/14 10:31 AM How much Rwkw did u get once done the dump pipe Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1452139 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 4m 17d Gender: Male Location: North West Hot Hell,VIC Posted 27/01/14 10:40 AM Share Posted 27/01/14 10:40 AM I would not give it a hard time until you get a retune and re adjust some parameters to suit the new hardware, otherwise at 18lb on the old tune it may GRENADE. Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1452140 Share on other sites More sharing options...
Jip86 Donating Members 12 Member For: 11y 10m 25d Posted 28/01/14 06:46 AM Share Posted 28/01/14 06:46 AM So originally you were making 300rwkw on 14 psi? Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1452278 Share on other sites More sharing options...
Vrdesign Member 42 Member For: 11y 4m 6d Posted 01/02/14 04:29 AM Author Share Posted 01/02/14 04:29 AM Yeah 14 trailing to 13. I'll know the gains one I re tune at the same boost. Haven't given it full throttle since I gave it a squirt after the install, not easy! Should be getting tuned in about a week. Just getting some suspension parts together so I can get it all done in one hit. Dump is a bit low so raising the front from ssl to sl with Koni reds. Should be sweet to drive after that! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1452887 Share on other sites More sharing options...
Jip86 Donating Members 12 Member For: 11y 10m 25d Posted 08/02/14 01:56 PM Share Posted 08/02/14 01:56 PM You should see some solid gains. I made 345 @14 psi with xforce 3.5" split dump so after a retune yours should pick up a handful of lost wasps. Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1454095 Share on other sites More sharing options...
Vrdesign Member 42 Member For: 11y 4m 6d Posted 10/02/14 01:04 AM Author Share Posted 10/02/14 01:04 AM nice! what mods you running?im booked in for a re tune this thursday! Link to comment https://www.fordxr6turbo.com/forum/topic/87240-front-half-upgrade-only/#findComment-1454302 Share on other sites More sharing options...
