  • Member For: 13y 1m 18d
Hi guys
Recently I had a brief check over the car and I found oil residue around the diff. I'm just wondering is it a big job to change the pinion seal? Does it require the diff to be emptied? Is there also a guide on how to change it?
post-50382-0-59736100-1388902554_thumb.j
Edited by ORANGEXR6T
https://www.fordxr6turbo.com/forum/topic/87211-worn-seal/
  • Bronze Donating Members
  • Member For: 12y 17d
Yes the seal change is relatively easy. And yes you gotta drop the oil. If you pm me your mobile number I will take a picture of the workshop guide.
Have you checked the oil level?
https://www.fordxr6turbo.com/forum/topic/87211-worn-seal/#findComment-1448391
  • Member For: 11y 10m 7d
Just before you do, it's a very common thing for the little fitting on the diff breather hose to clog. This then builds pressure in the diff & weeps from the seal. I've had mine cleaned & a oil change, haven't had an issue. This is a common problem for all diffs on all rwd cars. I would start there before you go pulling everything apart (yuk)
https://www.fordxr6turbo.com/forum/topic/87211-worn-seal/#findComment-1448796
