AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 9d Gender: Male Location: Canning Vale, W.A Posted 11/01/14 01:11 PM Share Posted 11/01/14 01:11 PM On 11/01/2014 at 8:57 AM, Kroozin said: That's pretty stout!<br />Do you know how much boost it was + what cooler he was using??<br /><br />19psi. Process west stage 3 kit, turbo side intake, 4' zorst, 1000c injectors, monsta built box only, stock engine. Oh and Surge tank with twin walbro 460s 2 Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 6m 15d Gender: Male Location: Perth, WA Posted 11/01/14 01:55 PM Share Posted 11/01/14 01:55 PM $1900 with actuator on the rotormaster site.How do these compare to a GTX3576r in terms of low end? Link to comment Share on other sites More sharing options...
Kroozin Menace Donating Members 1,990 Member For: 13y 11m 16d Gender: Male Location: Sydney Posted 12/01/14 12:09 AM Author Share Posted 12/01/14 12:09 AM Fmd!! 19lb!! I really gotta get a betta cooler :( Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 7m 18d Posted 12/01/14 01:10 AM Share Posted 12/01/14 01:10 AM On 11/01/2014 at 12:02 PM, Bomber said: Minor point. Does it come with the correct actuator bracket for FG or are they interchangeable?Comes with own actuator and bracket set up for the falcon The regular actuators aren't interchangeable The actuator rod is a dog-leg shape Inlet outlet 4/2.5 inch respectfully 1 Link to comment Share on other sites More sharing options...
dalts Member 755 Member For: 18y 10m 11d Gender: Male Location: brisbane Posted 12/01/14 02:04 AM Share Posted 12/01/14 02:04 AM On 11/01/2014 at 11:03 AM, rednose said: Here's hoping I have a bit more luck than you did with the Precision Lee.Have bought some 10.5 wide rear wheels and will be wrapping them with 305 RS3's so should be good.You should be fine george I'd be a lot more confident with it being water cooled now (very convenient ) That wheel and tyre combo should be the ultimate for grip on the street without going to a R compound tyre.Looking forward to seeing how it goes,keep us updated!Lee 2 Link to comment Share on other sites More sharing options...
RynoF6 Idiot Member Donating Members 446 Member For: 15y 2m 16d Gender: Male Location: Muswellbrook, NSW Posted 12/01/14 04:25 AM Share Posted 12/01/14 04:25 AM (edited) From everything I can find. A GTX3582r and PTE6235 will perform the same.6235 is a 6262 with the 35r turbine. The 6262 spooled slower than the GT35r but also had more topend.Smaller 35r rear wheel improves response and the GTX front wheel now provides same top end as the 62.6235 noiser equivalent of GTX35r Edited 12/01/14 04:26 AM by RynoF6 1 Link to comment Share on other sites More sharing options...
RynoF6 Idiot Member Donating Members 446 Member For: 15y 2m 16d Gender: Male Location: Muswellbrook, NSW Posted 12/01/14 04:45 AM Share Posted 12/01/14 04:45 AM Compressor wheelsGT3582r - 61.2mm inducer 82mm exducerGTX3582r - 62.5mm inducer, 82.5 exducerPTE6235 - 62mm inducer, 82mm exducer 1 Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 8m 29d Gender: Male Location: OZ Posted 12/01/14 05:30 AM Share Posted 12/01/14 05:30 AM On 12/01/2014 at 4:25 AM, RynoF6 said: From everything I can find. A GTX3582r and PTE6235 will perform the same.6235 is a 6262 with the 35r turbine. The 6262 spooled slower than the GT35r but also had more topend.Smaller 35r rear wheel improves response and the GTX front wheel now provides same top end as the 62.6235 noiser equivalent of GTX35r...you sure the new 6235 has a 35r turbine? It would be strange if PTE use a non-garrett CHRA and a Garrett turbine I would have thought.Although the dimensions of the compressors are the same, the design is quite different. Will be interesting to see the differences, personally I think it will be hard to gauge and will be subject to a bit of controversy! Link to comment Share on other sites More sharing options...
jimmixr Donating Members 686 Member For: 14y 7m 18d Posted 12/01/14 05:54 AM Share Posted 12/01/14 05:54 AM I think its more about response and spoolOutright hp is no biggy...Me personally was more concerned about the above mentioned...Theres no denying the GTX's menace.. Its proven time again..I've never done the norn so I guess this is just another "suck it and see"An overlay of the two dyno graphs from the same vehicle with just a turbo change will come Im sure..but till then..... 1 Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 11m 2d Gender: Male Location: Central Coast Posted 12/01/14 06:01 AM Share Posted 12/01/14 06:01 AM I think we are all looking for the holy grail of turbos. The spool time of the standard fg And the power of the gtx Wether the precision is or not that's another story Link to comment Share on other sites More sharing options...
