  • Member For: 12y 10m 7d
  On 02/01/2014 at 12:34 PM, freeze_dk said:
How you think ford make there money on labour
the be dealerships, right??
  On 02/01/2014 at 11:54 AM, Kroozin said:
That has gotta be the hardest way I have ever seen to remove the furker.
Then enlighten the OP.
  • Member For: 12y 9m
Where are you located mate?
If I remember rightly..
Remove intake to turbo and piping from compressor, cover them up suitably
remove heat shielding, there are some sh*tty bolts to get to from underneath... unless you have a hoist ( suggest spraying turbo manifold mount bolts with CRC or WD40/penetrene as soon as you expose them after removing heat shield)
Unbolt dump pipe at the turbo flange (that's where I dropped it)
remove boost actuator hose from actuator
remove coolant and oil feeds to turbo ( suggest coolant change at this point and oil change)
remove coolant drain and oil drain from turbo ( I took the oil drain off at the block... was just easier I thought)
crack turbo mount flange bolts
remove all mount bolts in turbo and lift out....
something like that.
Edited by Chaos310
  • Member For: 22y 2m 2d
Bubbles joins 2 Jan 2013
Bubbles makes first post 2 Jan 2013
Bubbles ask for help on first post 2 Jan 2013
Bubbles last active 2 Jan 2013
Bubbles gets helpful posts within 1 hr of his first post.
Bubbles does not think enough of the help offered to post up a follow up post.
Bubbles has now lost his right for helpful posts.
Edited by turbotrana
  • Like 3
  • Dropping a turd
  • Member For: 17y 7m 5d
Agree.
I just hit mine with a big hammer.
It normally only takes 2 hits but that can vary with the poundage of the hammer and amount of beers consumed
  • Like 3
  • Moar Powar Babeh
  • Member For: 19y 8m 9d
I just drive mine around. Fords awesome factory hardware and assembly methods gaurantee the turbo will fall off at some stage, you just gotta wait.
  • Like 8
