  • Member For: 17y 4m 5d
What would stuffed lifters cause?
I notice when I do a big warm up burnout and stop straigjt away the car idles real rough for 30 seconds then comes fine again, sometimes it stalls and when I try and start it the car winds over with no compression like the spark plugs are missing...... Is this a sign of the lifter not keeping up?
Im currently having a bad idle, miss and stall issue also. Once loaded up it goes fine. Jamie from forced performance has advised faulty lifters. Getting done this week. I will let you know if it fixes it.
  • Member For: 18y 1m 28d
I just bought lifters for mine for a rainy day, the best place I found was Tony at TBRE, it appears he has found the supplier that atomic use as he states they come in the same packaging. What he doesn't know 100% yet is if the ones atomic use come as is and they just on sell them and they are built as such. or if Atomic actually purchase them then modify in house. I haven't been able to see any difference yet. need to pull them apart and take some measurements
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 3d
Id put a few bucks on the fact atomic take them and make them suited to the aplication they sell them for
Bit like bosh to ID etc etc
Would be well surprised if they were apples for apples
  • Member For: 19y 9m 26d
Kosji do you have a wideband in your car? If not datalog injector pulsewidth and RPM with Livelink. Sounds outrageous I know...
