crossley Member 6 Member For: 15y 9m 24d Gender: Male Location: All over the place Posted 23/12/13 01:58 AM Share Posted 23/12/13 01:58 AM Hi all, quick question, did a search couldn't really find a lot of info. Noticed yesterday the ute, mk2 ba xr6t with 6sp is leaking coolant from bellhousing sort of starts about half way up each side and is running down. Cant see any coolant up the top, heater hoses etc all look good. I gather there is a welch plug on the back of the block somewhere. Is it just a box, clutch and flywheel out job to access it for replacement? Any one else had this problem?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/ Share on other sites More sharing options...
jules_1972 Member 39 Member For: 15y 6m 22d Gender: Male Posted 23/12/13 06:24 AM Share Posted 23/12/13 06:24 AM Pictures will help alot. Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1446915 Share on other sites More sharing options...
crossley Member 6 Member For: 15y 9m 24d Gender: Male Location: All over the place Posted 24/12/13 05:42 AM Author Share Posted 24/12/13 05:42 AM Not to sure how to post pics, if someone can tell me? Got the car on ramps so could have a good look and its running down the inside of the bellhousing out the inspection plate. Welch plug? What else is there? Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1447008 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 11m 2d Gender: Male Location: Perth Posted 25/12/13 10:44 AM Share Posted 25/12/13 10:44 AM Can use online pic sites like Photobucket. Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1447129 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 8m 30d Gender: Male Posted 25/12/13 10:55 AM Share Posted 25/12/13 10:55 AM Send me the pic. Frezz_20002@hotmail.com Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1447133 Share on other sites More sharing options...
crossley Member 6 Member For: 15y 9m 24d Gender: Male Location: All over the place Posted 26/12/13 11:17 PM Author Share Posted 26/12/13 11:17 PM email sent freeze_dk Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1447261 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 8m 30d Gender: Male Posted 26/12/13 11:39 PM Share Posted 26/12/13 11:39 PM (edited) Edited 26/12/13 11:40 PM by freeze_dk Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1447262 Share on other sites More sharing options...
crossley Member 6 Member For: 15y 9m 24d Gender: Male Location: All over the place Posted 03/01/14 08:45 AM Author Share Posted 03/01/14 08:45 AM As you can see its running down inside bellhousing leaking out. Can anyone help with this? Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1448253 Share on other sites More sharing options...
matsfgxr6turbo Member 388 Member For: 15y 4m 21d Posted 03/01/14 02:19 PM Share Posted 03/01/14 02:19 PM THAT MEANS YOUR CAR IS FAARKED!!!!! Seriosly you should get a mechanic to look at that it can't be good Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1448289 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 12y 2m 6d Gender: Male Location: WA Posted 03/01/14 03:02 PM Share Posted 03/01/14 03:02 PM Pull your starter motor out and check the drive gear. If you see evidence if coolant on it and inside your bell housing then yes it will most likely be the rear welsh plug. So yeh, box, torque converter and flex plate or box, clutch and flywheel depending in which way you swing. Link to comment https://www.fordxr6turbo.com/forum/topic/87115-coolant-leak-at-bellhousing/#findComment-1448291 Share on other sites More sharing options...
