Rachet Member 3 Member For: 11y 3m 24d Posted 19/12/13 08:54 AM Share Posted 19/12/13 08:54 AM I have a BA XR6t and the motor shat its self so for the right price I managed to track down a FG NA engine, I transferred everything from the broken BA to the newer FG motor including all my mods (larger injectors, bigger turbo, cold air induction, inter-cooler, 3in exhaust) After it was all installed by my mechanic he sent me home to run it in and said to come back when id done 500km, then we'll do a performance tune.apon returning and putting it on the dino to do a performance tune he could only safely get 180kW at 9 pound boost, when he tried for 11-14 pound the motor would knock so he backed off.I thought a stock FG Na engine could get 195kW and from what ive read and researched it is possible to turbo the FG Na engine with good results basically I have a performance car that's under preforming is there any reason for this to be happening?? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 19d Gender: Male Location: @ my laptop Posted 19/12/13 09:02 AM Share Posted 19/12/13 09:02 AM why are you asking us, shouldn't you be asking him or at least what did he say?what programme is he using to tune it?does he know the comp is different? Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 19y 11m 9d Gender: Male Location: In my house Posted 19/12/13 09:16 AM Share Posted 19/12/13 09:16 AM I thought you would be limited with the compression ratio of the NA. Link to comment Share on other sites More sharing options...
Rachet Member 3 Member For: 11y 3m 24d Posted 19/12/13 09:23 AM Author Share Posted 19/12/13 09:23 AM Firstly I need someone else knowledge on this situation I didnt get to speak to him, I only got told by the secretary. and he couldnt tell me why. you would think he would know about the difference in compression ratios but he did not mention anything to me before we started would that be what caused the knock? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 19d Gender: Male Location: @ my laptop Posted 19/12/13 09:26 AM Share Posted 19/12/13 09:26 AM does your mechanic have a dyno and software to adjust the factory ecu? Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 19y 11m 9d Gender: Male Location: In my house Posted 19/12/13 09:26 AM Share Posted 19/12/13 09:26 AM Possible.Trying to push boost in an engine that's running a higher compression ratio can cause detonation.You need to check out what the NA comp ratio is and ring a reputable performance shop to find out what how that setup should be doing . 1 Link to comment Share on other sites More sharing options...
Rachet Member 3 Member For: 11y 3m 24d Posted 19/12/13 10:17 AM Author Share Posted 19/12/13 10:17 AM he has the dino and the proper software to ajust the ecu,and he is supposed to be a reputable business. I need answers and if I cant get them off him I thought someone on here might know Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 1m 20d Gender: Male Location: Far north queensland Posted 19/12/13 10:37 AM Share Posted 19/12/13 10:37 AM everyone has told you mate, high compression = less boost before detonation Link to comment Share on other sites More sharing options...
FPV TRANNY Im the one and only Donating Members 3,557 Member For: 19y 11m 9d Gender: Male Location: In my house Posted 19/12/13 12:21 PM Share Posted 19/12/13 12:21 PM Doesn't the FG run Dual VCT?Are you running the BA ECU Still?It could be a variety of things mate.You need to take it to or talk to another tuning shop.Id also be looking at changing the compression ratio back to whats needed for turbo application.We are all just speculating. Link to comment Share on other sites More sharing options...
