fastfwd Member 103 Member For: 13y 4m 11d Posted 16/12/13 11:30 AM Share Posted 16/12/13 11:30 AM Hi all,I have recently replaced the turbo, new front mount, new piping. Basically had most of the induction and exhaust apart. I have put the car back together and its running but it goes into limp mode.Car wont throttle over 2-3000RPM, I figured I forgot to plug in a sensor. Went over all of the sensors and made sure they are plugged in correctly. All look fine.I have a SCT Chip with hand controller. Tried looking for the ecu to plug the hand controller into see if it has a diagnosis function to see what sensor is the issue but I couldnt find the ECU.Does the hand controllers have diagnosis settings? what would be the easiest way to diagnose this.Got a tune in the morning and need to sort it out before then. :( Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 11d Gender: Male Location: Perth Posted 16/12/13 11:39 AM Share Posted 16/12/13 11:39 AM Did you change injectors?OBD2 Diagnostics plug is located under the steering column basically in front for you RH need behind the fuse Panel. Link to comment Share on other sites More sharing options...
fastfwd Member 103 Member For: 13y 4m 11d Posted 16/12/13 11:59 AM Author Share Posted 16/12/13 11:59 AM I have different injectors but I didnt change them this time round. Was done on a previous tune. Link to comment Share on other sites More sharing options...
fastfwd Member 103 Member For: 13y 4m 11d Posted 16/12/13 12:05 PM Author Share Posted 16/12/13 12:05 PM Ok found it and did a "read dct's" under check engine settings. I figured day's were the sensors. This it the error. Is this the pressure sensor? Link to comment Share on other sites More sharing options...
matsfgxr6turbo Member 388 Member For: 15y 1m 29d Posted 16/12/13 12:49 PM Share Posted 16/12/13 12:49 PM If one leg moves slower than the other you are in limp mode my friend Link to comment Share on other sites More sharing options...
fastfwd Member 103 Member For: 13y 4m 11d Posted 16/12/13 01:12 PM Author Share Posted 16/12/13 01:12 PM Thanks mats Anyone know what this code is referring to? Need to find what sensor this is. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 11d Gender: Male Location: Perth Posted 16/12/13 01:21 PM Share Posted 16/12/13 01:21 PM Boost presure sensor. Lives on the under battery pipe on B series Sedans dunno where it leaves on Terris. Somewhere between the cooler outlet and throttle body. Link to comment Share on other sites More sharing options...
fastfwd Member 103 Member For: 13y 4m 11d Posted 16/12/13 02:05 PM Author Share Posted 16/12/13 02:05 PM Yeah was like I thought pressure sensor. Don't know but there must not been something wrong with the hose I used. Got it working. Cleared the limp mode and reset and all good Link to comment Share on other sites More sharing options...
