  • Moar Powar Babeh
  • Member For: 19y 8m 18d
  On 17/11/2014 at 1:19 AM, Whooby said:
I think they're hoping I'd just accept it and pay the bill myself.
This is the tactic used by most a/m warranty companies. The intend to wear you down and generally the hoops they make you jump through plus being without a car is enough to get most people to fold.
If you have the time/inclination/resources stick to your guns mate.
Also don't condemn the Aussie made car. Keep in mind the Trans is German and so is the cooler.
  • Like 2
  • Member For: 11y 6m 12d
I thought the Cooler unit was made in china now? Box aside the Ford Milkshake has been an issue for Ford before the ZF came along. The heat exchanger was still a problem here too.
The car is nice enough, I just haven't really formed any attachment to it. I don't find as comfortable to drive as my Cruiser or my Celsior. The power/speed it has would be what I like about it the most.
  • Member For: 17y 9m 22d
I actually got mad when I read this thread. The attempt by the warranty company to only cover the root cause of an issue is the most ridiculous thing I've ever read. Like if a timing chain guide failed they'd replace the guide but not the rest of the engine that's munched itself. I'd kick someone in the face if they suggested that to me. In fact if it's that easy to get out of claims, I'll start my own aftermarket warranty company and live rich.
I hope you get a good outcome, don't let it slide, most aftermarket warranty companies will only cover the first x amount (say $1500) of a major repair but I've never come across one that's as petty as this. In fact when you're facing a $6-$8k repair bill, it might be worthwhile to speak to a contract lawyer to see whether they actually have the ability to treat a claim like that.
  • New Member
  • Member For: 11y 1m 7d
Hang on a second....isn't the stock heat exchanger 'internal' to the gearbox? Therefore why it voids a new car warranty if you upgrade with aftermarket exchanger!
So my point is, if it's part of the gearbox.....it fails......fix the whole thing!!!
Dude that sucks!
  • Moar Powar Babeh
If by internal you mean mounted outside the gear box, on a separate sub assembly with hoses feeding it coolant and trans fluid...then yeah it's internal.
Otherwise its externally mounted (on the engine sump) and is not part of the gearbox assembly.
  • Like 4
The warranty I have has no claim limit per item so I wasn't worried I'd have to contribute to the cost of any repairs. But I didn't expect was their blurry interpretation of a word.
The g'box is associated damage, It's not a consequence. Running off the road and smashing through someones fence is a consequence, Having to hire a car is a consequence. Failure of a component which is required for the operation of another is a direct association with the original component failure. All your examples make sense to us normal people. Failed injector = cracked piston (extreme but possible) doesn't mean replaced injector and leaving motor fuct.
I'm not done fighting yet.
  • Like 5
  • Member For: 11y 6m 21d
I would say the gearbox failing and some how locking up causing you to crash is consequential.
A necessary component of the gearbox failing that intern ruins the box is a failure of the box. Regardless of where the component is mounted. Its factory fitted, zf deems it necessary and every god dam drop of fluid runs through it. Its part of the box...allll day long.
More to the point ford covers it under warranty, no floor mat excuses or anything.
Edited by barnz
  • Like 2
Well I got my response from Ford, I had a good laugh when I read it......
Sorry the quality is a little crappy, If you can't read it I'll type the text in.
post-75521-0-90923200-1416447802_thumb.j
Hugh.
