  • Member For: 13y 3m 30d
High pressure cooling system are common in Nascar. That bumper to bumper drafting they do causes a lot of heat build up in the rear car. They run 30lb in the systems I was told - and I have a vague idea that the rules for 2012?? restricted the pressure levels allowed in the radiator. That is a lot and I wonder who does their systems.
Those housing issues are a damn nuisance in the ford. Frankly, some sort of remote or in-line thermostat housing would be better. You could machine it up and at least get some precision around the sealing.
  • Bronze Donating Members
  • Member For: 11y 11m 21d
I know if we don't use genuine CATERPILLAR coolant in CAT engines the aluminium parts will corrode at a faster rate. Even if it it states on the drums that it can be used for cat engines. Have you tried genuine ford coolant?
I think it is davie Craig water that makes variable flow electronic water pumps. So you can take your thermostat out and machine off the vanes on your ford water pump. That will allow for maximum flow when you need it.
