FiftyOne Bronze Donating Members 1,145 Member For: 11y 8m 4d Gender: Male Posted 09/12/13 09:24 AM Share Posted 09/12/13 09:24 AM Chucked a new 82c thermo in the ute a few weeks ago after I noticed that the original (or what I think was the original) had a hole in it. I was a little unsure what the temps should be but they seemed low as the needle only got just under 1 quarter all the time. After the swap it runs at a needles width over the quarter & seems to sit more consistent as well as quicker. Only problem is that the fuel use is a little higher than I was expecting (13-14 per 100k, yeah it's still pretty good but still seems just a tad thirsty) & then last time I put the OBD datalogger in the fuse box & took it for a drive I saw this on the attached imageI'm not really sure that the sensor should see such a dramatic flux of temp like that. Am I correct in thinking I have either an earthing issue, a bad connection or a fault somewhere for it to do that? I'm thinking if that's the case, the temp could be rapidly fluctuating & causing the higher fuel use than I was expecting. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 9m 6d Gender: Male Location: @ my laptop Posted 09/12/13 09:57 AM Share Posted 09/12/13 09:57 AM it's common that the temp reading drops out with many obd2 readers on some cars Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 6d Gender: Male Location: Perth Posted 09/12/13 10:13 AM Share Posted 09/12/13 10:13 AM 82c just over 1/4 is correct. Link to comment Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 11y 8m 4d Gender: Male Posted 09/12/13 11:31 AM Author Share Posted 09/12/13 11:31 AM Thanks guys, appreciate it Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 7m 12d Posted 09/12/13 11:50 AM Share Posted 09/12/13 11:50 AM What data logger is that Link to comment Share on other sites More sharing options...
