aps Member 1,505 Member For: 21y 10m 13d Posted 24/01/04 07:26 AM Share Posted 24/01/04 07:26 AM Guys, I been thinking what is a reasonable price to pay for a 6 speed manual trans upgrade, and have any members on the forum seriously considered this as an option. I would like to have your thoughts so post away all feedback is welcome.PETERAPS Link to comment Share on other sites More sharing options...
CnC SportCompact.biz Member 328 Member For: 21y 10m 7d Location: Canberra Posted 24/01/04 07:45 AM Share Posted 24/01/04 07:45 AM I figure people wont want to may more than $5,000 as a complete kit.My gut feeling however is that a fully engineered kit with a T56 will be up around the $8,000 mark. Link to comment Share on other sites More sharing options...
aps Member 1,505 Member For: 21y 10m 13d Posted 24/01/04 08:06 AM Author Share Posted 24/01/04 08:06 AM By the way has anyone on the forum actually broken or damaged the T5 xr6t manual trans ? You hear of much criticism though I have not seen or heard of a broken T5 , yet.PETERAPS Link to comment Share on other sites More sharing options...
sixfan Flaccid Member Donating Members 2,503 Member For: 21y 7m 29d Gender: Male Location: NOONAMAH, go figure..... Posted 24/01/04 08:19 AM Share Posted 24/01/04 08:19 AM If you classify broken you mean crunching into 5th,there are quite a few of us.P.S come up with a price below $6000 and delete the speed limiter and I'll take one. Link to comment Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 5m 1d Gender: Male Location: NSW Posted 24/01/04 09:26 AM Share Posted 24/01/04 09:26 AM Mine crunches into 5th but that's all, 5 to 6k would be worthwhile for the box coversion. Link to comment Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 1m 3d Location: nowhere in particular Posted 24/01/04 09:31 AM Share Posted 24/01/04 09:31 AM BCLs (Brian) sounded pretty crook when he let me have a drive the other week (It was already like that, I didn't cause it OK!). Not crunching but bearing noises and it was hard to get into gear. I believe he has a T56 on order already from somewhere. Link to comment Share on other sites More sharing options...
justind Member 90 Member For: 21y 9m 1d Location: Melbourne Posted 24/01/04 09:33 AM Share Posted 24/01/04 09:33 AM Mine wouldn't downshift 5th to 3rd. I had it replaced then the new box only had 2,000kms and started to crunch into 5th and all gears are loose. approx 30mm slack in all gears. Link to comment Share on other sites More sharing options...
aps Member 1,505 Member For: 21y 10m 13d Posted 24/01/04 09:49 AM Author Share Posted 24/01/04 09:49 AM If you classify broken you mean crunching into 5th,there are quite a few of us.P.S come up with a price below $6000 and delete the speed limiter and I'll take one.No I dont mean crunching into gear this is obviously a synchro ring problem , I am asking if anyone has actually broken a gear or a cluster gear or had a big gearbox failure of some description.PETERAPS Link to comment Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 26d Gender: Male Location: Sydney Posted 24/01/04 11:00 AM Share Posted 24/01/04 11:00 AM Peter,Prior to my Nizpro upgrade the box did not crunch, but shift quality I considered to be poor from day 1.My gearbox started falling apart at around 300rwkw, in the interim stages of tuning, and I’m now running a lot more power than that. I fully expected the T5 to last a while; based on comments from various people that it was a strong box.Oh, and the clutch slipped at 280rwkw, and was replaced.It is now drivable, whines very loud (even when not under load), and very hard to get into gear, and getting progressively worse. I can select every gear, and it does not crunch. However, on the freeway I often cannot downchange from 5 to 4. It will not last, and an upgrade is mandatory. Currently I drive my car no more than 1 day a week.The nominal rating of the T5 is 447NM, and if a stock car has a torque of 450NM, then my car is rated around 765NM, based on a torque increase of 70% (based on dyno graphs) at only 3200 revs. For me the T5 replacement must happen, and it must be very strong.I am happy to dump the T5, as I never liked it, especially when you compare it to the jap boxes around.How much would I pay? $5-$8 was my expectation originally.I have researched the matter, and there are very few options available, either T56 or changing to auto (you can refer to my thread at http://www.fordxr6turbo.com/forum/index.ph...wtopic=8495&hl= ).As you are no doubt aware Wal Woods does 6-speed T56 conversions, and has done so for the AU XR8, and now the BA, and he has an excellent reputation.The matter is not just about the gearbox; you must consider the gearbox and clutch as a package. In terms of the gearbox, ideally you want the shifter to come through in the same spot. You want good ratios, which are suited to the Ford turbo. I want something with good shift quality, and which shifts much better than the T5. 2-3 shifts must be quick and smooth, which I can’t do in the T5.The clutch replacement will be added to the price. I don’t want a pressure plate pressure that is too heavy, as I currently have. With the T56 I have thus opted for a twin-plate clutch, which a more expensive option, but which should be much easier to drive, as it will be a smooth change with a bit heavier pedal effort. I don’t want a single plate clutch that requires a substantially beefed up pressure plate, that will be less easy to drive.The stock XR6T T5 has ratios 2.95/1.94/1.34/1/0.73.The T56 suggested as the option for the XR6T has ratios 2.97/2.07/1.43/1/0.8/0.62, which would work quite well.It uses the same internals as a Mustang COBRA R.Attached is a sample photo of a T56 shaft compared to a T5; quite a difference in size.My T56 upgrade will happen in the next month.Brian Link to comment Share on other sites More sharing options...
bloan Member 379 Member For: 21y 6m 12d Gender: Male Location: Melbourne. Posted 24/01/04 12:26 PM Share Posted 24/01/04 12:26 PM Why is it that nearly eveyone is hellbent on replacing the T5 with a six speed? If the T5 is that bad and needs replacing why just replace it with a stronger 5 speed? IMHO a sixth gear is a complete waste of time and money unless of course you live in the NT! Link to comment Share on other sites More sharing options...
