k31th less WHY; more WOT Site Developer 29,056 Member For: 16y 8m 15d Gender: Male Location: Melbourne Posted 25/09/18 10:52 PM Share Posted 25/09/18 10:52 PM A 73.1mm centre bore wheel would fit, but would feel floaty. You want an aluminium hub-ring to go from the factory size inner-diameter of 70.5mm (based on that link I sent earlier) to the outer diameter of 73.1mm of the wheel itself. 1 Link to comment Share on other sites More sharing options...
Kanga New Member 8 Member For: 6y 3m Posted 25/09/18 11:19 PM Share Posted 25/09/18 11:19 PM So, can anybody tell me how these bad boys would fit under the wheel arches of my FGX ? Diameter - Front - 19x8.5 - Offset - Front- 42.5PDiameter - Rear - 19x9.0 - Offset - Rear - 45.0P Easy/tight/fugeddaboutit ? There are a heap for sale on Gumtree in good nick from $700 to $1,500 a set of four with good rubber. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,056 Member For: 16y 8m 15d Gender: Male Location: Melbourne Posted 26/09/18 12:11 AM Share Posted 26/09/18 12:11 AM yeah, they'll probably fit... You'll be about 12-13mm closer to the suspension strut on the inside of the front. You'll be about 22mm closer to the suspension strut on the inside of the rear and about 4mm closer to the guard on the rear (which is perfectly fine). Measure your current setup and how close it is to the suspension and make sure those numbers fit based on your current setup. (hint - I used this website: https://www.willtheyfit.com/index.php?width=245&aspect=35&diameter=19&wheelwidth=8&offset=36&width2=245&aspect2=35&wheel_size=19&wheel_width=9&offset2=45) 1 Link to comment Share on other sites More sharing options...
Mike C New Member 2 Member For: 4y 8m 20d Posted 10/04/20 03:33 AM Share Posted 10/04/20 03:33 AM Hi, I have the 2017 Mustang wheels. I have an Ford 2016 FGX one tonner. The rear fit fine on the back but the fronts are very tight and close to the suspension strut. Tyre place says no way that's illegal. They are genuine ford and I'd like to know what I need to do to fit these? Is a spacer needed? I have 1/2 nuts to suit the Ford fgx. The stud pattern is the same. What about the offset? will it clear all things in cornering? Link to comment Share on other sites More sharing options...
