  • RNS10S
  • Member For: 18y 10m 17d
All the trouble and cost of extra plates and certificates, you should have just gone with a bigger cooler and been done with it.
Edited by rednose
  • Member For: 13y 7m 11d
Put it this way... I got my $1000 plazmaman cooler which was second hand unused for $150.
I already had the plates of metal from some old off cuts so that was free.
it took me around 1 hour to cut/paint and an engineers certification which if he approves straight up will only cost me $150. If I have to edit it and come back then it will cost me an extra $150.
So at this moment best case scenario I will have only spent $300 completely certified, included in the certification is the front mount itself.
I don't feel any of this is a waste of time or money thus far.
Not trying to insult you but this "getting a bigger cooler" to solve the issue is neanderthal approach to the solution. Because people are scared to touch the crumple bar doesn't mean it cant be done safely and legally.
  • Member For: 17y 7m 9d
Once it's done just get it dynoed with the mods as planned, let it cool to same temp and stick something in the cutout section to block it again and remeasure, just out of curiosity! Easy way to compare the effect of the changes (after front bar mod anyway).
  • Member For: 22y 3m 3d
I would have welded in some 75 x 25 RHS top and bottom. That would have given you a gap in the middle and some strength. 3mm flat bar is not really strong enough.
The main problem with intercoolers is heat soak being too close to the radiator/condenser. There is a company that manufactured/s a combined radiator/intercooler setup which is a bit dumb if it can be avoided.
If I was you (now that you have gone this far) I would cut out the whole factory bar out and put in some RHS steel that would allow the intercooler to be positioned away from the hot stuff. I always consider getting the intercooler as far away from hot stuff as possible. Even stepping the bar in towards the engine and having the intercooler in front of the fabricated cross bar.
  • 2 months later...
