  • I <3 Floods
  • Member For: 13y 8m 21d
You know.. I'm not often involved in mechanical things..
But structures I know..
And I'm fairly sure that you can't engineer significant structural changes to a car chassis/reo/important hard bits, without significant engineering assessment. Unfortunately this is why manufacturers smash cars into barriers at 59kmh.. To see what happens when you can't really predict what will happen.
I am interested to see the outcome of your engineering assessment though..
  • Member For: 11y 5m 8d
  On 11/12/2013 at 11:50 PM, ratter said:
the 3mm steel plate he has fitted may be heavier than what was removed
This haha
I don't think it's worth the time and effort to do this when there is a lot better modifications that could be done
  • Member For: 18y 6m 24d
Regardless of what was in the way of the cooler, it would have performed better due to the size and thickness over standard. This piece you cut out isnt going to do nothing because as mentioned, the bumper still goes over it.
  • Member For: 13y 4m 30d
No I am cutting a portion of the bumper out that goes right over it, highlighted below. I will chuck some mesh gridded mesh similar style to the one around the ford badge and paint it black.
I understand it will perform better, but im not after better, im after best. I want to optimize as much of the the mods I make as possible.
why is everyone a h8er? If it can be done safely and legally then all benefits to me for getting the most out of a front mount possible.
Its not as expensive as people think to get an engineers assessment/certification and it didn't take me that long to complete, probably took me an hour to cut and paint.
If I had a dyno in my back pocket I would complete a first test on it without the mods to the bar and the bumper then complete a second with the same setup to see the difference in heat soak on the cooler. Then I would complete the same 2 tests on it with the bumper and bar modded. I could never guarantee that it would or wouldn't make a difference if these tests weren't done but considering the way a intercooler works more flow across it = better.
  On 12/12/2013 at 2:51 AM, ratter said:
so did the last car you had engineered have air bags?
Yes it did, nissan 200sx s15 - both passenger and driver, both of them blew on impact, my face can tell you that. Hurts....
