fastfwd Member 103 Member For: 13y 4m 29d Posted 10/12/13 09:33 AM Author Share Posted 10/12/13 09:33 AM It's stage two rated at 800hp. Plasmaman. Big enough.. I still wanted to keep. Some safety aspect And yes it's in my TT which has that perfect grill that can be cleanly cut out and have some after market mesh of some sort. All black along with the car so it's all hidden. Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445043 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 25d Gender: Male Location: Perth Posted 10/12/13 10:40 AM Share Posted 10/12/13 10:40 AM It will work. Except you just compromised the structural integrity of the front end. Hope you don't have an insurance claim Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445057 Share on other sites More sharing options...
fastfwd Member 103 Member For: 13y 4m 29d Posted 11/12/13 12:27 AM Author Share Posted 11/12/13 12:27 AM I have welded some thick plates on each side of it, taking it to an engineer next week to get certified so I don't have that problem. Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445138 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 25d Gender: Male Location: @ my laptop Posted 11/12/13 01:13 AM Share Posted 11/12/13 01:13 AM hopefully they don't have to crash test it to pass Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445142 Share on other sites More sharing options...
Seaton Donating Members 537 Member For: 12y 7m 25d Gender: Male Location: Sydney Posted 11/12/13 01:29 AM Share Posted 11/12/13 01:29 AM I have worked in smash repairs for 15 years as a painter, I would have zero problems taking the plastic cross section out on an fg, and I have spoken to a lot of top panel beaters about this, but the problem with removing the whole reo on your car like you have, is that if you get a hit from the front side on, the rails will not be braced together, even removing it like you have, your weakining that side front on support, in a case of a decent hit, the rails won't move across together, you will probably just buckle the bar reo in the middle. Cars have that brace between the rails for a reason. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445145 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 25d Gender: Male Location: @ my laptop Posted 11/12/13 01:47 AM Share Posted 11/12/13 01:47 AM I think ford engineers are probably a little higher in knowing what that plastic brace does compared to the rest of us, I have a customer that is an engineer at ford, he was more than willing to sacrifice a little performance rather than remove that bracing. Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445148 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 22d Gender: Male Posted 11/12/13 03:51 AM Share Posted 11/12/13 03:51 AM You shouldn't have cut that bar. It does tie the front in together. Also there is really no issue with power on these cars, so whatever little you loose, you can pickup elsewhere in a well developed turbo setup : enough power to make the driveline the problem point. Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445177 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 5m 30d Gender: Male Posted 11/12/13 05:20 AM Share Posted 11/12/13 05:20 AM Actually just cut the rest off... You have gone that far why not.... But like the rest have said... You should not have but it at all... If you ever sell and you do somehow get a RWC to sell it... I really feel sorry for the next person who buys it if you don't say anything. Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445195 Share on other sites More sharing options...
fastfwd Member 103 Member For: 13y 4m 29d Posted 11/12/13 06:59 AM Author Share Posted 11/12/13 06:59 AM (edited) I completely understand all of your concerns. Cutting the bar does sound stupid and maybe classed as car taboo. But I didn't just cut it willy nilly without prior knowledge. I opened this tread to get idea's because I didn't want to cut the bar if others had done something different with airflow by getting around it. But seeing as it seems like everyone just leaves the bar blocking 30-40% of the cooler, "buying a bigger one" seems like a slightly useless resolution. I know most people just do this but I don't really like that fix when I know other things can be done.I have completed this exact edit on a previous car. I brought it to an authorized engineer certified by Department of transport WA. He told me to have 3mm steel plates welded across the bar horizontally on each sized of the cuts to reinforce the changes. He signed off on the changes and gave me a certification, this cost me $150 for certification. In this car I also was involved in a T bone crash which wasn't my fault. My car went directly into the side of another car what didnt give way. My car was a complete write off and the HBF claims investigator did ask about the changes made a week lster and I showed him the certification and he approved it. I was paid out for my write off without issues.I will be taking my territory to the same engineer, I have already welded the steel plates across the modifications, the same as last time. If he feels that the modification isn't structurally sound even with the welded plates then I will weld the originals back into place as they came (this is why I don't want to cut the whole thing off as this is stupid plus it is unsafe). I do want to keep my car legal and safe. taking it to an engineer for approval will give me this piece of mind and will also give Department of Transport authorization if anything happens. Edited 11/12/13 07:02 AM by fastfwd Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445209 Share on other sites More sharing options...
Jstplyn Member 65 Member For: 11y 5m 8d Gender: Male Location: Melbourne, Victoria Posted 11/12/13 07:03 AM Share Posted 11/12/13 07:03 AM No performance gains to see here Link to comment https://www.fordxr6turbo.com/forum/topic/86942-crumple-bar-blocking-the-cooler/page/3/#findComment-1445211 Share on other sites More sharing options...
