  • Replies 28
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 3d
  On 02/12/2013 at 10:03 PM, Kyle Booth said:
It does it for about 30seconds or so then sorts itself out !
Sounds like crap valve springs to me
  • New Member
  • Member For: 13y 1m 16d
Yea but they are brand new. Plazmaman springs. Tested at 90psi.
My tuner thinks its "maybe" vct actuator.
Have to take a data log to see if they are advancing and retarding and not stuck in 1 spot
  • Member For: 12y 11m 16d
  On 02/12/2013 at 4:44 AM, turbotrana said:
Inlet cam timing solenoid or exhaust.
I wonder if these faults always show up fault codes cause my FG does the rough idle in the morning then is fine after 20 seconds. I should also check the cam timing first I guess.
I believe it was exhaust with mine. However can't be sure as my mechanic handled all of it. Mine was the opposite. Fine for 20 secs then started.
  • Member For: 18y 7m 6d
Pos fords. I've seen a symptom of a car jumping a tooth because the plastic guide broke off and got stuck on the gear
  • Member For: 12y 9m 27d
My car had displayed some of these symptoms which I put down to bad fuel quality.
Car has just been tuned and filled with fresh BP98 prior.
Car (G6ET) had pinging issue at top end and where tuner would normal advance timing (little turbo running out of puff), he had to retard timing due to ping.
He thought it had been filled with 95 at some stage.
My question is if car had jumped a tooth and car has just been tuned would it cause ping though the top end?
Edited by GeGe6
  • 3 months later...
  • Member For: 11y 5m 12d
I've had one experience with my car when I was slowly rolling up to a red in with clutch in in 2nd, then light went green and changed to 1st and gave it a little throttle to match up, about a second after I let the clutch out car went into a limp mode.
Wouldn't rev over about 1000-1500, check engine sign came up and started running super lumpy and rough. So I pulled over tuned it off, started again and problem was all gone.
I've heard this happening to afew other people and their always worried that something needs replacing in there car. The thing is it happened to me in a brand new 2014 mk2 xr6t with 350kms on it.
My mate (who I was driving with at the time) has a 2011 f6 with 30000kms on it and it's happened to him a couple of times as well.
I'm not too worried about it, but just thought id let people know it's happened to me in a brand new car.
Sent from my iPhone using Tapatalk
