  • Member For: 22y 19d
  On 01/12/2013 at 11:29 PM, towsw001 said:
I had almost the exact same issue of which my mechanic had to replace the cam timing solenoid and phaser.
Mine would be fine for first minute or two when the engine is cold and then kick in exactly as you said.
As Mick said it could also relate to the timing jumping a tooth.
Inlet cam timing solenoid or exhaust.
I wonder if these faults always show up fault codes cause my FG does the rough idle in the morning then is fine after 20 seconds. I should also check the cam timing first I guess.
  • Replies 28
  • New Member
  • Member For: 11y 6m 28d
  On 02/12/2013 at 9:30 PM, Kyle Booth said:
My bf f6 does it but only after ive hit the limiter in a gear then coming to a stop. Becomes very rough and wants to konk out. Any ideas?
I dropped my car to the mechanic yesterday afternoon to get looked at. They said it was possible that the cam had jumped a tooth, hopefully I'll have a full diagnosis by this afternoon.
They mentioned that they had seen jumped teeth on the B series cars, not too many on the FG's though. Does your car consistently idle roughly after this happens or does the issue disappear after a restart?
  • New Member
  • Member For: 13y 1m 1d
It does it for about 30seconds or so then sorts itself out !
  • Member For: 14y 5m 28d
  On 02/12/2013 at 9:54 PM, ratter said:
sometimes there are no obvious symptoms as the can has closed loop control
So no engine lights or any tell tale signs Ratter?
  • Member For: 18y 10m 23d
some owners have complained about the power change or intermittent idle and we have picked up on the jumped teeth, one FG we had had a bad rattle but one FG had jumped 3 teeth and caused the light to come on intermittently
  • New Member
Just heard from the mechanic. The car has indeed jumped a tooth (spot on ratter) and needs to be adjusted. The mechanic has recommended replacing the chain and the tensioner to reduce the risk of the problem reoccurring any time soon. Is that the usual fix?
