mike0819 Member 69 Member For: 11y 5m 9d Posted 26/11/13 12:25 PM Share Posted 26/11/13 12:25 PM hi mine is 2008 model, in nz we can legal remove the cat converor. has anyone done it before? does it give a deeper sound? I heard you get a stronger gas smell if that is true. also if I remove the cat, will it make my exhaust droning? I also thinking of fitting an x force muffler. does it make it sound better? Link to comment https://www.fordxr6turbo.com/forum/topic/86891-fg-xr6-turbo-remove-cat-convertor/ Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 9d Gender: Male Location: Victoria Posted 26/11/13 12:27 PM Share Posted 26/11/13 12:27 PM If you remove the cat the car will need a retune to avoid over boosting. Link to comment https://www.fordxr6turbo.com/forum/topic/86891-fg-xr6-turbo-remove-cat-convertor/#findComment-1442627 Share on other sites More sharing options...
matsfgxr6turbo Member 388 Member For: 15y 2m 29d Posted 26/11/13 03:16 PM Share Posted 26/11/13 03:16 PM Remove the cat and put some 3" pipe in place it will be the ultimate hiflow cat but will make the car smell a bit and sound quite a bit louder though I have a hiflow and cat my car still smells so its much of a muchness but free power is good a tune will definently be required though Link to comment https://www.fordxr6turbo.com/forum/topic/86891-fg-xr6-turbo-remove-cat-convertor/#findComment-1442643 Share on other sites More sharing options...
fatz_f6_typhoon Member 395 Member For: 12y 4m 4d Gender: Male Location: 2145 nsw Posted 26/11/13 06:38 PM Share Posted 26/11/13 06:38 PM Like the boys said mike you can't remove the cat with out retuning it There not like the jappas where you can take the cat out and it self adjustsThey are tuned to what gear they have in them the only thing you can do is a Cat back muffler system and k&n panel filter any thing more after that needs to be tuned Have a read through the fourms there is lots of info on here Link to comment https://www.fordxr6turbo.com/forum/topic/86891-fg-xr6-turbo-remove-cat-convertor/#findComment-1442644 Share on other sites More sharing options...
