turkle New Member 5 Member For: 13y 1m 26d Posted 24/11/13 01:03 PM Share Posted 24/11/13 01:03 PM Hi All - long time lurker first time poster I recently bought a xr6t bf2 and its got an issue I'm hoping someone can help me with.When I start the car and start driving (forward or backwards) the traction control light comes on and something from the front of the car goes click click click click... then everything's fine. Say I'm reversing and feathering the brake I can feel it through the brake pedal and a little bit in the steering. The light will stay on for the rest of the trip and the whole thing starts again next time.Any idea what this could be?The car has 19 inch wheels 245 wide and the steering is alot heavier than the AU xr6 I had previously - is heavier steering normal??It also has a ZF 6 speed, no mods and full service history.And btw, if this has been asked before don't chew me out, its my first post because I'm GOOD at using the search function.Cheers! Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/ Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 27d Gender: Male Location: WA Posted 24/11/13 01:53 PM Share Posted 24/11/13 01:53 PM Sounds common. I would try clean all the steel filings off the abs sensors for a start. I dare say the clicking sound is your abs module releasing brake oil pressure to the caliper on the same rotor that the u/s abs sensor is on. Or a relay switching due to a u/s sensor. I have never diagnosed this problem before but I would start with disconnecting one sensor and then driving and then braking until you do all four or the problem goes away. I would start with your left hand side of the car as that is the side that hits the dirt and any puddles on the road. If you have no luck mate let ya know and we'll try and come up with some more money savings ideas haha. Oh and the sensor is behind your brake discs and the pickups are on the back of the hubs, so get the wheels, calipers and discs off to give everything a clean with a wire brush. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1442258 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 25d Gender: Male Location: Perth Posted 24/11/13 02:25 PM Share Posted 24/11/13 02:25 PM I like turkles 2 Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1442259 Share on other sites More sharing options...
turkle New Member 5 Member For: 13y 1m 26d Posted 25/11/13 11:42 AM Author Share Posted 25/11/13 11:42 AM Awesome, thanks AdamIan.If I had to guess I'd say the sound is coming from the left front.Forgot to mention slotted rotors have been installed as well, perhaps that's causing more gunk to clog the ABS sensor. Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1442424 Share on other sites More sharing options...
turkle New Member 5 Member For: 13y 1m 26d Posted 25/11/13 11:43 AM Author Share Posted 25/11/13 11:43 AM Is there something I can buy to plug into the ECU and get the fault codes myself?Even if it doesn't help with this I'm sure it will come in handy in the future. Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1442427 Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 9m 1d Gender: Male Location: Brisbane Posted 25/11/13 12:12 PM Share Posted 25/11/13 12:12 PM On 25/11/2013 at 11:43 AM, turkle said: Is there somewhere I can buy a butt plug.Sure mate. Any sex shop. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1442429 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 27d Gender: Male Location: WA Posted 25/11/13 12:26 PM Share Posted 25/11/13 12:26 PM Ye there is mate. I have a code reader but anything cheap will only pick up certain codes and not really trans faults and brake codes. My Xcal 3 seems to pick up everything I have had so far. There worth 700new. 200 second hand but will need unlocking if you choose to tune your car which is worth about 300-400 ( I think) I can't see slotted rotors making much difference to the dirt stuck to the abs sensors. The front left sensor is what I have changed out before. What state you in? I may be able to help you out with a code read. Unfortunately I don't sell sex toys. But Ralphy likes turtles :/ Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1442431 Share on other sites More sharing options...
turkle New Member 5 Member For: 13y 1m 26d Posted 25/11/13 01:02 PM Author Share Posted 25/11/13 01:02 PM Cheers mate, I'm in Perth, NOR Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1442439 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 27d Gender: Male Location: WA Posted 25/11/13 01:34 PM Share Posted 25/11/13 01:34 PM Cool. PM me if you want me to check the codes. Otherwise monster torque is very flexible and also give you a read and erase. I will create a fault on my falcon to be sure the Xcal reads abs codes. Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1442443 Share on other sites More sharing options...
ToXic BF Beast New Member 18 Member For: 10y 5m 21d Gender: Male Location: Dee Why Posted 01/11/14 03:29 AM Share Posted 01/11/14 03:29 AM Hi TURKLEDid u ever get this issue sorted?? Mine has done it since I got it last yr (BF XR6T)Only just realising how much I hate itThe "clunk clunk grind grind" disappeared for 2 days, every thing was quiet and... Like a normal car. But the noise is back( my TCS light came on & couldn't be switched off)So I'm 99% they're relatedMine goes mental every time it come to a slow stop or starting to crawl like in traffic.Let me know mate Anything to avoid the Ford dealers Link to comment https://www.fordxr6turbo.com/forum/topic/86870-tractionabs-issue-just-after-start-up/#findComment-1509556 Share on other sites More sharing options...
