JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 28d Gender: Male Location: Adelaide Posted 20/09/17 07:52 PM Share Posted 20/09/17 07:52 PM Bit off the pace there matty, what tyres did you go with ? Link to comment Share on other sites More sharing options...
Gabbo_32 Member 69 Member For: 10y 9m 7d Gender: Male Location: SE Melbourne, Victoria Posted 20/09/17 09:50 PM Share Posted 20/09/17 09:50 PM @MattyP what pressure are you running your current compressor setup at? I'm having dramas at the moment trying to get a Procharge 67mm / stage 2 turbine wheel to stay at 24psi. Link to comment Share on other sites More sharing options...
MBAF Bronze Donating Members 2,156 Member For: 8y 5m 14d Posted 20/09/17 11:25 PM Share Posted 20/09/17 11:25 PM What size is the gate? 3 hours ago, JETURBO said: Bit off the pace there matty, what tyres did you go with ? Cheap hard china specials....annnnnd wouldnt drop pressures Link to comment Share on other sites More sharing options...
Gabbo_32 Member 69 Member For: 10y 9m 7d Gender: Male Location: SE Melbourne, Victoria Posted 21/09/17 12:40 AM Share Posted 21/09/17 12:40 AM internal gate. was 38mm initially with the stage 1 9 blade turbine wheel and cnc housing port. then went to 40mm with the stage 2 9 blade turbine wheel and some hand porting combined with the cnc port job on the housing. wanted to try and keep it at 20psi, but not having much luck Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 7m 28d Gender: Male Location: Adelaide Posted 21/09/17 03:18 AM Share Posted 21/09/17 03:18 AM Not all port jobs are equal I can maintain 16psi on a 66mm wheel with one of my 38mm port and flapper jobs who's done all this for you Andrew ? who's tuning it as this can play a big part to 1 Link to comment Share on other sites More sharing options...
Gabbo_32 Member 69 Member For: 10y 9m 7d Gender: Male Location: SE Melbourne, Victoria Posted 21/09/17 03:32 AM Share Posted 21/09/17 03:32 AM Turbo was done by Procharge and tuning by APS mate Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro...tbh ;) 8===} Gold Donating Members 16,077 Member For: 9y 11m 30d Gender: Male Location: South Australia Posted 21/09/17 03:42 AM Share Posted 21/09/17 03:42 AM 5 hours ago, Gabbo_32 said: I'm having dramas at the moment trying to get a Procharge 67mm / stage 2 turbine wheel to stay at 24psi. You can't run less than that? That turbine wheel is supposed to flow more than a stocker. Run it at gate pressure without the solenoid in the mix and see what it does. Link to comment Share on other sites More sharing options...
Gabbo_32 Member 69 Member For: 10y 9m 7d Gender: Male Location: SE Melbourne, Victoria Posted 21/09/17 03:55 AM Share Posted 21/09/17 03:55 AM I believe APS tried that as well with no luck. With a Turbosmart Actuator and a standard Garrett one. Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro...tbh ;) 8===} Gold Donating Members 16,077 Member For: 9y 11m 30d Gender: Male Location: South Australia Posted 21/09/17 04:08 AM Share Posted 21/09/17 04:08 AM Is your flapper getting stuck as it opens and opening less than it should be? Has that been checked? Not that it's an apples to apples comparison but mine (66mm comp/stock turbine) will run 12psi off the gate. Link to comment Share on other sites More sharing options...
Gabbo_32 Member 69 Member For: 10y 9m 7d Gender: Male Location: SE Melbourne, Victoria Posted 21/09/17 04:48 AM Share Posted 21/09/17 04:48 AM That was an issue initially, flapper getting stuck, but was fixed when swapped over to a genuine Garrett actuator. I'm a little confused by it too, it's like the compressor makes more than the turbine housing and wastegate can handle. I'm no expert though, just going off what has been relayed to me by my mechanic from tuner. Will open another thread about it when I get results tomorrow (hopefully) as I'm stealing @MattyP thunder Link to comment Share on other sites More sharing options...
