  • MattyP
  • Cruise Control
  • Member For: 13y
So first sort of big issue.
I wouldnt call it a break down but its done it 3 times now
Once running on e85 once on 98 and once on e10.
Car drives fine then starts to lose power then if I use more than min throttle and starts misfiring and spluttering and has zero power.
Timing drops right down to between -2 to 8 degrees, boost at zero psi and really starts coughing and popping
I pull over, idle sounds okayish and then I rev it and it splutters and sounds like its dropped a cylinder or two.
Heres the wierd part
Let it sit for 5 and shes all good again, any ideas??
Planning to change spark plugs and coils anyway tomorrow as part of the service but could it be anything else
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m 3d
Split feed hose on fuel pump
You have the winner winner chicken dinner Keep Paying Money unit yeh lol ;)
  • MattyP
  • Cruise Control
  • Member For: 13y
This has only happened 3 times in the last year. Surely a split hose would cause far more dramas?
Why would I lose all timing?
Iam only spit balling mate, normally to hard to diagnose cars over the interwebs
Rapid erattic timing is typical for the engine in a freefall mode or trying to maintain what a mechanical part might be letting down
Need to see/feel/log the car when something like this happens
  • MattyP
  • Cruise Control
  • Member For: 13y
Yeah its true
I never thought id be the kinda guy that posts that but here we are
Its a just bizaire that its done it so infrequently with different weather.
I was thinking possibly a gummed up throttle body and/or plugs and/or coils and/or fuel filter
She just hit 165000kms so im doing all those things anyway and hopefully it doesnt come back
Well look fg's typically don't do coil packs but my F6 needed them at ~120,000kms
T/B
Plugs
Coils
Fuel filter
Manifold bolts/gaskets are all cheap items that a falcon can use so start there as it seems the donk could use that gear anyway at those kms
Then see where your at
New gaskets are cheap and then you can tick them off the list for a start
New bolts can never hurt
Always genuine coils even for FG
