  • Puff
  • Member For: 10y 3m 2d
@NA_TURBO You've had some of these issues. Check ya battery?!
  • Member For: 12y 1m 3d
Probs won't hurt to check your charge rate - load alternator up with lights on high, AC on etc and make sure she holds 13.8+V no higher than 15.
Also doesn't hurt to check for battery drain, FG's do draw a bit of current for a short while after locking, but will settle down. Anything higher than ~100mA after 15 mins needs checking out.
20-30 mins daily should be fine if charge rate and drain are ok.
  • Member For: 11y 2m 19d
  On 02/04/2019 at 2:34 AM, JETURBO said:
I’ll take that lol 😂
its just one of those areas to nail perfection anyway I can but others have worked this out also years and years ago
Expand
No doubt....
Most keep their tricks up their sleeves though
  • Like 2
  • Member For: 9y 6m 23d
Expand
Yep checked battery, not the cause.
  On 13/02/2019 at 9:32 AM, masda74 said:
so the car hit 112000km last week. what really got me this week was the battery finally gave up.
Had to go and get another Century 67EFMF from Supercheap.
The last I remember, I got one for $189.  Inflation seems to be rising higher than my pay rise.
New price of battery is $235. like wtf.
Car now cranks over first time every time. only issue that I am still facing now is that the aircon doesn't always work.
Every so often I will turn the aircon on and only hot air comes out.
I have to pull over and stop. Turn the car off. wait a bit start car and then I get cold air.
like wtf? does this mean that it needs to be re gassed? also the cold air doesn't come out as cold as it used to.
Expand
My BF does this, but I only have to pull over and let it idle to make the AC turn on then it's fine but it never cuts out. Just stalls when slowing down sometimes.
  • To Loud
  • Member For: 13y 5m 1d
  On 02/04/2019 at 2:20 AM, JETURBO said:
I’ve had some decent skeptics turn their nose up on this but take my word for it a Supercheap brand battery will out go a Century and have least issues on a falcon specifically !
I NEVER use a Century battery ever after coming to this conclusion
true story is true
Expand
Wish I had known this before. I thought they were a good battery cause of the 620CCA and how it turns the falcon over pretty well.
Did try a supercheap battery when first replacing the original battery and had to take it back cause it was 420CCA and would not crank over the next morning for some reason.
I would go the optima, but securing it would be my biggest concern. would I be able to do it????
@JETURBO what battery do you recommend to use then?
  • To Loud
Cool. Thanks for that. I take it you don't get them from supercheap then?
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 11m
No mate the reference was really for “any other battery” even a “supercheap” brand with appropriate capacity will out do a Century !
I Get them from Sprint auto parts but I think they’re a SA company only 🤔
its around $170-$200 depending on sales etc etc and never had one fall over ever
  • To Loud
Thanks mate. I did check supercheap site and did enter 630CCA batteries and they only show the century stuff.
Staying away from them from now on. Too late to change now.
I checked the Exide site and their store locator is I <3 Bananased. When I clicked on contact us, it showed some addresses.
I will find a store locally. Thanks again for the information.
