Quiet Hiflow Fuel Pump For Fg?
Z2TT
  • Member For: 12y 10m 10d
Hi Guys.
I want to upgrade my fuel pump to handle about 400rwkw as I understand the factory one doesn't flow enough.
What fuel pumps are you guys running and how quiet/loud are they?
I'm after a brand that will be the quietest possible.
Thanks.
  • Bronze Donating Members
  • Member For: 11y 11m 15d
Any external pump is noisy. I run a warlbro 450 in tank fuel pump and I cant here it at all. I'm also at 400rwkw.
Edited by AdamIan69
  • Member For: 14y 6m 16d
How are Process west's new external fuel systems for noise with the internally mounted fuel pumps? I have 2 044's external surge and they arent what you would call quiet, inside the car, stereo takes care of that noise, but externally people always tell me there is something wrong with my car at lights due to the noise they hum out. I havent heard much about the KPM twin in-tank setup but that might be an option for you in terms of noise reduction.
  • 570Nm @1800rpm
  • Member For: 21y 6m 14d
^^^^^ Combined with a high flow in-tank pump that does not mind a few more volts, it should cover the needs for 400rwkw easy. ^^^^^
I have never had an external surge setup but have heard them and they can be pretty noisy.
I did have an in-tank Welbro pump before and that was pretty good I though, only marginally louder then the OEM pump.
You can buy a complete a in-tank cradle with larger pod assembly and high-flow pump that will cater for your power needs.
