Drivers Seat Worn
jas98
  • Member For: 12y 7m 11d
My ba xr6t sean used to be a ex cop car in NSW so the drivers seat is worn (the foam)
its the back of it not the part where you sit haha so if you lean teh wrong was you can feel the metal frame which does hurt at times.
im aware you can get replacement backings from ford for about 2-350 bucks but is there any other alteratives? how much would a upolser charge for a quick fix?
also how do you remove the fabric? it does have side air bags too
I was thinking of stuffing some foam in there haha as rest or seat is perfect
  • 7 months later...
  • All round good guy!
  • Member For: 16y 9m 25d
How did ya go with this? Get it fixed? If so, how much and what did you do?
Chees.
  • loitering with intent
  • Member For: 21y 6m 15d
related, I have a 1cm split on my custom leather on the drivers side bolster from
general wear and tear,Otherwise like new
are leather repair kits any good?
  • Member For: 12y 2m 26d
My old mans territory had the leather peeling away on the side bolster from people getting in and out. He got a local upholsterer to fix it and it looks like factory. He replaced the whole leather piece (it's actually not leather to begin with) with better material and it only cost him $100. Dad couldn't have been happier with the result
  • Moar Powar Babeh
  • Member For: 19y 5m 11d
I just had the drivers seat in my Typhoon renewed. Base Springs repaired and new foam added, both back and side bolsters replaced and reshaped out of stiffer foam, two cracks in the frame welded up and pilling removed fron the suede. All fir the princely sum of $130.
  • Member For: 17y 3m 10d
I've hear a crack sound sometimes as I get in to mine now. Thought it would be plastic broken but if Ralph had a couple spots that needed welding, maybe I should get mine looked at by the same bloke.
