  • Member For: 12y 1m 11d
Hi guys I bought a ba turbo a while ago and wanting to get up closer to the 400kw mark so far I have.
Forged rods, hypertek pistons, valve springs,
Atomic billet oil pump, hardened cam gears.
Stock turbo with flapper mod 12 psi actuator.
Plazmaman 4" intake
Plazmaman plenum
Plazmaman surge tank Bosch 044
after market dump pipe, cat and mandrel bent twin 2.5" exhaust
6 speed manual
Eaton true track Diff.
Drilled injectors to 60lb
Old 2.5" in/out Process west stage 2 core.
Tune made 320rwkw on 17.5 psi of boost.
Not grate figures.
Just bought the New process west stage 2 core with
3"in/out.
Siemens deka 60lb
Still making the bracket for the front mount.
Should be more efficient cooler than the older model.
Car goes good but should go better with less psi.
Thoughts anyone.
Edited by mosha1982
Elite automotive Brisbane mate.
Felt like they where a good choice as Steve has a quick ba and I have seen plenty of good cars there.
  • Member For: 15y 6m 3d
twin 2.5 will be a restriction at 400rwkw
I thought most people ran twin 2.5 "
A fella from 6 boost said slap a second 044 in and they Jamie could possibly pull 400.
I Will see how it goes with the New pw cooler and deka's after the retune but I don't see that getting me up much more hp
Depends on the cat and mufflers.
sent from phone via idags4lyf free app
  • Member For: 17y 1m 9d
Yeh Steve is helpful. I recon you will go 400 on twin 2.5". What exhaust did henz have on his Ute?
Manta twin 3"
With plaz cooler + plenum+ intake
Ported turbo + actuator
Valve springs
Surge+ 044 + 60s.
Twin 3"
407rwkw at heaps of boost. Think 360 at 16psi iirc
Edited by Henz
