  • Member For: 12y 8m 28d
Ok so when I bought my turbo the guy said when installing the turbo make sure the oil drain is 10 degrees off TDC and coolant feed from the bottom.. now if u ask me its logic that the oil drain should be at the bottom??
Also the vacume hoses from the boost solinoid. When I pulled off the turbo there was one vacume hose going into the compressor housing and the other going into the actuator. Ok so on my external wastegate I have 2 vacume nipples, where does the second one go? Im going to be running a twin gate setup so im assuming ill have to run a t-peice to each wastegate as well?
A little help would be much appreciated xoxoxo
https://www.fordxr6turbo.com/forum/topic/86793-help-with-turbo-install/
