Rusty Rotors
shane0nz
  • Member For: 12y 1m 4d
2011 fg xr6 non turbo.. behind the rear wheel when removed is a thin plate which had ugly rust on it, so I thought whip that off for an inspection well the rotor, bearing nut, shaft is covered in rust. both sides?
Is this normal? if I need to show a pic then I guess it isn't
  • Member For: 20y 2m 24d
Rotors will lightly rust in about an hour after being washed down. However, a run will either:
  1. remove the rust and leave the metal bright and shiney
  2. remove the rust and leave behind a light coating of pad friction material
Whether you get result 1 or 2 depends on:
  • the chemistry of your pads
  • the nature of your run
The only rust that should remain on the disc is:
  • on the disc hub
  • on the outside edge of the disc
  • inside the disc on the vanes or pillars
Any other rust present would appear to be wrong.
Edited by aiboart
thanks for the reply aiboart, I realize I didn't describe very clearly. you are right the rotor disc is shiny. It is the hub I am looking at. these rusty hubs look like they're 20 years old not 2. It hasn't got a towbar so it hasn't sat in the drink.
  • www.australianflag.org.au
  • Member For: 19y 8m 22d
Unprotected metal and elements equal rust. Pic to conclusively say but I'm sure what your seeing is normal.
PS it's a Ford the technology is 20 years old.
