Bonjaz Donating Members 1,841 Member For: 16y 6m 3d Gender: Male Location: CQ Posted 27/11/13 09:29 PM Share Posted 27/11/13 09:29 PM yea I think they had a bad batch a while back and had a few failures, but my understanding was they were all recalled and there hasnt been a failure in a while and elite did say they havent had any that they have done fail so meh Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1442827 Share on other sites More sharing options...
SipposBFT Member 81 Member For: 15y 9m 20d Posted 30/11/13 11:33 PM Share Posted 30/11/13 11:33 PM so Glad I read this post...my cars just started to do the same thing... changed the coils & plugs (which Im glad I did anyway...carsjust hit 150,000) & the thing does exactly what you guys mentioned "rydeit". Was hoping my car already had the typhoon springs as its an update...which I was told most had but it looks like ive just analysed my prob .. the rough idle on cold & all. Ill get my mate to change them @ his workshop. Ive also heard the Boss v8 springs are a good upgrade as well. Anyone else vouch for this?CheersDanny Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1443258 Share on other sites More sharing options...
Bonjaz Donating Members 1,841 Member For: 16y 6m 3d Gender: Male Location: CQ Posted 01/12/13 01:16 AM Share Posted 01/12/13 01:16 AM go crows or atomic mate, dont muck around with anything else, for the sake of an extra $100-200 it will be worth it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1443271 Share on other sites More sharing options...
SipposBFT Member 81 Member For: 15y 9m 20d Posted 01/12/13 02:15 AM Share Posted 01/12/13 02:15 AM ill check them out. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1443277 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 17d Gender: Male Location: Probably above atmospheric pressure Posted 01/12/13 02:45 AM Share Posted 01/12/13 02:45 AM Springs are only like $300 or something anyway? Labour is the $$$ part. Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1443284 Share on other sites More sharing options...
SipposBFT Member 81 Member For: 15y 9m 20d Posted 04/12/13 10:10 AM Share Posted 04/12/13 10:10 AM just to get some more answers as well...why does my car also seem to backfire through the exhaust...cant see whay the extra boost would affect exhaust spring pressures Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1443917 Share on other sites More sharing options...
corey122 New Member 3 Member For: 11y 5m 17d Gender: Male Location: WELLINGTON NZ Posted 01/01/14 02:51 AM Share Posted 01/01/14 02:51 AM hey guys mine's got rough idle when warm has done that since ive had it 6mths,what cores it no one in nz can tell me they reckon lose inter cooler piping but its tight Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1447956 Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 1m 16d Gender: Male Location: Victoria Posted 01/01/14 01:49 PM Share Posted 01/01/14 01:49 PM Could be a vacuum leak(throttle body gasket or anywhere on the exhaust side) , O2 sensor, spark plugs, loose pipe, split engine mount, the list is endless. Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1448024 Share on other sites More sharing options...
corey122 New Member 3 Member For: 11y 5m 17d Gender: Male Location: WELLINGTON NZ Posted 01/01/14 10:35 PM Share Posted 01/01/14 10:35 PM thanks m8 ill check it out Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/4/#findComment-1448050 Share on other sites More sharing options...
