Rydeit Member 327 Member For: 12y 10m 28d Gender: Male Location: Adelaide S.A Posted 15/11/13 04:24 AM Author Share Posted 15/11/13 04:24 AM Cheers Bonjaz I recon valve springs is my issue. Was always under the impression that the f6 valve springs would last but obviously not. Any reccomendations in valve spring department. Plazmaman always seems good. Does the car need a re tune after valve springs aswell? Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1440418 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 14d Gender: Male Location: Probably above atmospheric pressure Posted 15/11/13 05:38 AM Share Posted 15/11/13 05:38 AM (edited) My car did it hot. I was also down over 10rwkw after having springs put in at XFT (crow springs) so opted for a retune, picked up some power (322 before springs, 236 after), I'm so keen to see my mph now that my ZF is rebuilt and isn't slipping! Edited 15/11/13 05:39 AM by -SteveR- 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1440429 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 16d Gender: Male Location: Perth Posted 15/11/13 05:54 AM Share Posted 15/11/13 05:54 AM 322 before........... 236 after.....ummmmmmmmmmmmSprings tend to play up when hot. Heat affects the steel and contributes to the lose of spring force. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1440436 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 14d Gender: Male Location: Probably above atmospheric pressure Posted 17/11/13 04:04 PM Share Posted 17/11/13 04:04 PM Typos be damned!322 before, 326 after Peak figures suck for comparing anyway, it feels a tad stronger the whole way. Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1440872 Share on other sites More sharing options...
Rydeit Member 327 Member For: 12y 10m 28d Gender: Male Location: Adelaide S.A Posted 18/11/13 01:44 PM Author Share Posted 18/11/13 01:44 PM Haha thought something was up. Yeh I will go either crow or plazmaman Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1441108 Share on other sites More sharing options...
fatz_f6_typhoon Member 395 Member For: 12y 5m 7d Gender: Male Location: 2145 nsw Posted 18/11/13 08:31 PM Share Posted 18/11/13 08:31 PM Yeah change them mine showed no sign of float snapped,dropped valve cracked piston no 2 .... Crow springs went in hahaha Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1441119 Share on other sites More sharing options...
RynoF6 Idiot Member Donating Members 446 Member For: 15y 4m 18d Gender: Male Location: Muswellbrook, NSW Posted 18/11/13 11:28 PM Share Posted 18/11/13 11:28 PM (edited) Just replaced my coil packs. Had noticed a huge power loss for some time. Got so bad in the higher gears was like traction control was kicking in. Ran 11.3@113mph so power was definately down. Priblem only realy showed up in higher gears. Pulled the codes on the xcal(no check engine light) and sure enough all coils bar num 2 were playing up. Edited 18/11/13 11:33 PM by RynoF6 Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1441149 Share on other sites More sharing options...
jas98 Member 1,048 Member For: 12y 10m 16d Gender: Male Location: Maryborough Qld Posted 19/11/13 05:01 AM Share Posted 19/11/13 05:01 AM stupid Q but you can tell exactly which coils are playing up on a scanner? is that for all ba-fg's? Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1441212 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 16d Gender: Male Location: Perth Posted 19/11/13 05:02 AM Share Posted 19/11/13 05:02 AM Yes you can Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1441213 Share on other sites More sharing options...
turbojosh Donating Members 284 Member For: 12y 4d Gender: Male Location: St Marys 2760 Posted 19/11/13 05:23 AM Share Posted 19/11/13 05:23 AM I'm getting the same problem with mine, booked in with Joe at CMS to take a look... Fingers crossed it's nothing too bad... Link to comment https://www.fordxr6turbo.com/forum/topic/86771-difference-between-failing-valve-springs-and-stuffed-coilsplugs/page/2/#findComment-1441218 Share on other sites More sharing options...
