GeGe6 Donating Members 1,978 Member For: 12y 7m 6d Gender: Male Location: Perth, SOR Posted 08/12/13 01:27 PM Author Share Posted 08/12/13 01:27 PM (edited) What about getting the fuel in tank tested, where can I go to do that? I would hate to do the retune with united 100 and have similar thing happen. Edited 08/12/13 01:32 PM by GeGe6 Link to comment Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 10m 16d Gender: Male Location: Canning Vale, W.A Posted 08/12/13 01:46 PM Share Posted 08/12/13 01:46 PM Power coming on sooner probably has a bit to do with the psi difference Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 7m 6d Gender: Male Location: Perth, SOR Posted 08/12/13 01:56 PM Author Share Posted 08/12/13 01:56 PM Issue is, timing needed to be retarded due to pinging through top end. Tuner suspects fuel is contaminated with 95Ron or bad batch! Would like to get to bottom of it and will start with getting fuel tested to rule it in or out. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 3m 17d Gender: Male Location: Perth Posted 08/12/13 01:56 PM Share Posted 08/12/13 01:56 PM Definitely. But why not wind it up. Link to comment Share on other sites More sharing options...
GeGe6 Donating Members 1,978 Member For: 12y 7m 6d Gender: Male Location: Perth, SOR Posted 08/12/13 01:59 PM Author Share Posted 08/12/13 01:59 PM Can you explain that? Link to comment Share on other sites More sharing options...
Z2TT Member 714 Member For: 12y 8m 17d Posted 08/12/13 03:10 PM Share Posted 08/12/13 03:10 PM (edited) I would have asked to get the tank drained and filled with fresh 98 while it was still at the workshop.Could have been a bad batch of fuel or a mix between 2 different fuels, try driving it a while and filling up so you have 98 in thereonly, it seems that BP is the preferred one then get it tuned again.After the pinging is ruled out then you can see how the car drives.With about 300rwkw, I'm happy for the most part with how mine goes after a tune, it's not the bestas there are some things that I just haven't had time to get checked out but it will definitelybe quicker everywhere and get upto speed faster.Your dyno graph seems fine to me and making the power but I guess your having some sort of issue after that Edited 08/12/13 03:17 PM by Z2TT Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 9m 9d Gender: Male Location: Central Coast Posted 08/12/13 07:40 PM Share Posted 08/12/13 07:40 PM I'll PM HIM.McMatty, you running 4" dump?Yeah mate It doesn't add that much power but gives much more response and torqueBut I seriously reckon drain the fuel and try again on a different servos bp98 or United 100And why no e85?? Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 22d Gender: Male Location: Perth, WA Posted 08/12/13 09:21 PM Share Posted 08/12/13 09:21 PM As Aaron suggested United 100 is another option and probably easier yo get our way compared to e85. Problem is though if it is not the fuel then it could be a waste of time and money getting it retuned. If you google fuel testing Perth, there are a couple of places that do it but it's not cheap. Mick, if it was me I would also change the intake pump. You can get a replacement drop in cradle for around 300 with a high flow welbro pump. Sent from my GT-I9300 using Tapatalk Link to comment Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 12y 9m 9d Gender: Male Location: Central Coast Posted 08/12/13 10:51 PM Share Posted 08/12/13 10:51 PM (edited) As Aaron suggested United 100 is another option and probably easier yo get our way compared to e85. Problem is though if it is not the fuel then it could be a waste of time and money getting it retuned. If you google fuel testing Perth, there are a couple of places that do it but it's not cheap. Mick, if it was me I would also change the intake pump. You can get a replacement drop in cradle for around 300 with a high flow welbro pump. Sent from my GT-I9300 using Tapatalk Where from? I'm looking at getting this done as well Edited 08/12/13 10:51 PM by McMattyP91 Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 22d Gender: Male Location: Perth, WA Posted 08/12/13 11:23 PM Share Posted 08/12/13 11:23 PM (edited) Ask your tuner about fuel pump. Otherwise if you want to supply or fit yourself you can get one of these http://pages.ebay.com/link/?nav=item.view&id=290601707527They also have e85 pumps and bigger cradle pots etc.http://pages.ebay.com/link/?nav=item.view&id=261241856172 Edited 08/12/13 11:29 PM by XtRmn8 Link to comment Share on other sites More sharing options...
